Indigo Renderer 2.4.3 Released
CoolColJ
Re: Indigo Renderer 2.4.3 Released
Post by CoolColJ » Wed Apr 28, 2010 8:43 pm
I noticed that Indigo continues to render in the background when you press the stop button...
ENSLAVER
Post by ENSLAVER » Wed Apr 28, 2010 8:47 pm
CoolColJ wrote:I noticed that Indigo continues to render in the background when you press the stop button...
Happened to me when I first downloaded and used it. Then stopped.... I thought it was just something I did wrong as a noob.
Post by StompinTom » Thu Apr 29, 2010 3:33 am
Bit of a silly thing: when you have the "Lock Aspect" button enabled, it always locks the larger dimension to Width, even if my image is in a portrait format.
Post by Borgleader » Thu Apr 29, 2010 4:40 am
StompinTom wrote:Bit of a small thing: when you have the "Lock Aspect" button enabled, it always locks the larger dimension to Width, even if my image is in a portrait format.
fixed ;)
Post by StompinTom » Thu Apr 29, 2010 6:49 am
I still say silly! ;)
everwind
Post by everwind » Thu Apr 29, 2010 9:13 am
okay, 2 bugs I saw with both 32 bits and 64 bits version on windows 7 x64 :
- when you use selection tool, the selection trembles (except when you select in the direction of DOWN - RIGHT) - so I confirm the bug
- Indigo still not accept special caracters in repertory (ex : my name is mikaël and indigo make an error when it tries to import a file in my directory, very boring, but no problem to export)
SPEED : no problem for me with the scene I'm currently using, they are a little faster than before
Post by Zom-B » Thu Apr 29, 2010 9:53 am
everwind wrote:- Indigo still not accept special caracters in repertory
The is a big chance that this is the exporters fault
Post by lycium » Thu Apr 29, 2010 10:32 am
Thanks for the bug reports on the selection tool and aspect ratio, added to the bugtracker!
Post by neo0. » Thu Apr 29, 2010 9:05 pm
So.. what can we expect in the next release?
galinette
Post by galinette » Thu Apr 29, 2010 9:10 pm
About the bug causing a crash when minCosTheta or maxCosTheta are used in the blend shaders. Will this be fixed, or will the use of these functions be forbidden in blend shaders?
Etienne
Soup
Post by Soup » Fri Apr 30, 2010 3:55 pm
Here's the documentation for the Network Manager and the not-so-secret Automatic Slave-On-Screen-Saver-tron.
Indigo Network Manager.pdf
(66.95 KiB) Downloaded 285 times
galinette
Post by galinette » Fri Apr 30, 2010 7:46 pm
This seems interesting... I work in a company with more than 300 desktops machines (dual core) which are almost never used at night... gaah
Etienne
everwind
Post by everwind » Fri Apr 30, 2010 9:26 pm
I spotted another bug I've ever seen but I don't remember when : with some scene when you put a material to specular, the render never starts, it's only written "done 0.0000 samples 1.#INFO micro-seconds / sample ...", but Indigo uses 100% of the CPU and never render a picture.
I will try to give you a .igs example :-)
kikeonline
Post by kikeonline » Wed May 05, 2010 10:14 am
Using Blendigo 2.2 doenst save the un-tonmapper image.... when I use Indigo 2.0.12 it does saves it.
Post by neo0. » Thu May 06, 2010 12:06 pm
Are we looking at another communication black out? :(
