I just noticed this problem too, not with the meshes, but opening an igi and adjusting it and then trying to save a version as tiff or png, Indigo gives an error saying the file cold not be saved.bubs wrote:once I do open it I can't even save it out as another image format, meaning the .igi is pretty much useless to me...
Indigo Renderer 3.6.16 Beta Release
FakeShamus
Re: Indigo Renderer 3.6.16 Beta Release
Hi Oscar,Oscar J wrote:It only contains an emitter (didn't want to upload my Koenigsegg) - which I can't hide from the camera.
There was a bug in path tracing modes where emitters weren't hidden from the camera. I have fixed for the next version (3.6.17).
Thanks for bug report!
Whoops.FakeShamus wrote:I just noticed this problem too, not with the meshes, but opening an igi and adjusting it and then trying to save a version as tiff or png, Indigo gives an error saying the file cold not be saved.bubs wrote:once I do open it I can't even save it out as another image format, meaning the .igi is pretty much useless to me...
Fixed for next release.
It sounds like you are resuming from a scene file that no longer has some of the meshes it needs.bubs wrote:I tried to resume render from .igi and got the following message;
Scene parsing error: Error loading model 'C:\Users\Home\AppData\Local\Temp/dca29729-9db5-4716-bde0-a160803569fc.igmesh': Failed to open file 'C:\Users\Home\AppData\Local\Temp\dca29729-9db5-4716-bde0-a160803569fc.igmesh' for reading. (In element 'mesh', around line 3, column 9)
Indigo version: Indigo Renderer v3.6.16.2, Windows 64-bit build.
No metadata.
Please contact support@indigorenderer.com if you have any questions.
When I checked the Temp folder there was no .igmesh file at all... I've never had this issue before, and whilst the .igi file will open by itself in Indigo, once I do open it I can't even save it out as another image format, meaning the .igi is pretty much useless to me...
Am I doing something silly here?
Is this a bug with not saving the temp mesh? I was trying to resume minutes after the .igi save. I hadn't purged anything or turned my computer off or anything...
Why not simply follow the path on your computer that Indigo told you it can't read from :)bubs wrote:Is this a bug with not saving the temp mesh? I was trying to resume minutes after the .igi save. I hadn't purged anything or turned my computer off or anything...
Do you have this issue all the time or only once?
