Shader request
5 posts • Page 1 of 1
delle
Shader request
Post by delle » Sat Nov 08, 2008 3:36 am
Hi to all, I'd like to learn Indigo Shading Language.
Since there is no tutorial available except the API Reference, I ask to some good fellow to try to help me to develop the shader that created this Picture "Shader.jpg". (of course not created with Indigo) :wink:
It uses one texture (Texture_Decal.png) to blend two different textures (Texture_01.png and Texture_02.png). The result is used for the Diffuse Albedo.
Note: I don't want to blend two different materials with a texture, I want to create a new triplet (RGB) to use it as albedo, bump, displace... with a shader.
I know that I can blend two materials but I want to learn ISL
:wink:
Thank you.
Delle
Shader result
MSUdom5
Post by MSUdom5 » Sat Nov 08, 2008 4:42 am
Hi delle,
This one is pretty simple and can be achieved with this code:
def blend(vec3 tex1, vec3 tex2, real blendamt) vec3: add(mul(tex1,blendamt),mul(tex2,sub(1.0,blendamt)))
def eval(vec3 pos) vec3 : blend(sample2DTextureVec3(0,getTexCoords(0)),
                                               sample2DTextureVec3(1,getTexCoords(0)),
                                               doti(sample2DTextureVec3(2, getTexCoords(0))))
Basically, the blend function returns a new rbg vector with the blended color. It samples the two rbg textures, and returns a combination of the two based on the "decal" texture.
And with ISLPreviewer, you can try things like this quickly. :)
Post by CTZn » Sat Nov 08, 2008 7:05 am
Awesome, dude !
What about adding buttons in the texture manager to change textures positions (or click'n'drag over new positon) ? Maybe not usefull for simple shaders, but if it's a complex one, that could save some hassle I guess.
Low priority req anyway :)
(doh I thought I was in the islp thread )
delle
Post by delle » Sat Nov 08, 2008 8:43 pm
Thank you MSUdom5!
Delle
Post by Kram1032 » Sat Nov 08, 2008 8:53 pm
nice :D
