Indigo v0.6 test 4
Indigo v0.6 test 4
Post by OnoSendai » Mon Oct 09, 2006 9:48 pm
v0.6 test 4:
just fixes a meshlight bug that was causing lots of noise in test 3.
http://www.bennolan.com/nick/indigo_06_test4.zip
Changelog:
* fixed meshlight bug causing noise
manitwo
Post by manitwo » Mon Oct 09, 2006 11:27 pm
Hi
i modified my infile.txt a bit to make it more pleasant for the eye.
nothing special, but maybe some people would have a better over-view on the infile.
Maybe you could also modify the infile for the next release or use eventually this :)
What do you think?
Hope you don't mind :| :)
---------------------------------------------------------- INDIGO SETTINGS ---------------------------------------------------
----- File loading settings --------------------------------------------------------------------------------------------------
"scenefilepath" "testscenes\ior_test.xml"         -- Scene xml file to load.  Relative to working directory
                                                  -- (e.g. indigo.exe path)
                                                  -- Alternatively, this path can be an absolute path,
                                                  -- (eg c:\indigo_scenes\testscene.xml)
----- Output image dimensions ------------------------------------------------------------------------------------------------
"width"  "600"                                    -- Note that the ratio of these should match the camera aspect ratio
"height" "450"                                    -- defined in the scene xml file.
----- Metropolis light transport settings ------------------------------------------------------------------------------------
"metropolis" "true"                               -- if true, use MLT, if false, use pathtracer
"large_mutation_prob" "0.4"                       -- Probability of using fresh random numbers.
"max_change" "0.02"                               -- max mutation size, must be in range [min_change, 1)
"max_num_consec_rejections" "100"
----- General tracing parameters ---------------------------------------------------------------------------------------------
--"russian_roulette_live_prob" "0.8"              -- 0.7
"max_depth" "1000"                                -- max ray bounce depth.
"bidirectional" "true"                            -- if true, indigo will use bidirectional pathtracing
----- Path tracer settings ---------------------------------------------------------------------------------------------------
"strata_width" "5"                                -- number of samples per pixel = strata_width*strata_width
----- Network rendering settings ---------------------------------------------------------------------------------------------
"frame_upload_period" "20.0"                      -- number of seconds between uploads of image to network master
----- Miscellaneous settings -------------------------------------------------------------------------------------------------
"halt_time" "-1"
"logging" "true"                                  -- if true, indigo will write to log.txt
"image_save_period" "40.0"                        -- number of seconds between saves of the render to PNG and EXR.
"save_tonemapped_exr" "false"                     -- if true, indigo will Write .exr tonemapped render as well as normal PNG
"save_untonemapped_exr" "false"                   -- if true, indigo will Write .exr untonemapped render as well as normal PNG
"num_threads" "1"                                 -- number of threads that will be used
"cache_trees" "true"                              -- if true, indigo will save mesh kd-trees into /tree-cache
not sure if all explanations on the right still make sense after i modified them a bit.
zuegs
Post by zuegs » Mon Oct 09, 2006 11:31 pm
YEAH.... v0.6test4 ROCKS !!! :D :twisted: :D
Great work Nick
manitwo
Post by manitwo » Mon Oct 09, 2006 11:35 pm
oh yes ... forgot that .. the new version really rocks!!! :D :D :twisted:
psor
Post by psor » Mon Oct 09, 2006 11:52 pm
Thanx Nick! This update is really appreciated! :D :D ;)
*thumbs up*
take care
psor
"The sleeper must awaken"
tizxx
Post by tizxx » Tue Oct 10, 2006 12:38 am
Very beautyfull render... thanka a lot.
:lol:
kirpre
Post by kirpre » Tue Oct 10, 2006 12:58 am
In testing the v0.6 test 4, should we still be using the Indigo 0.6test1 (beta1) export script for Blender or is there a newer version? Thanks.
kirpre
debris
Post by debris » Tue Oct 10, 2006 1:05 am
Working great here with the Blender beta1 exporter.
Great renderer BTW! :)
Version 0.6test4 beats all my expectations. Now I'm just waiting for the XSI exporter to finally arrive and I'll be in heaven.
Thx Ono-Sendai!
P.S.: Are there plans to give indigo some sort of minimalistic GUI to e.g. adjust tonemapping settings on the fly?
arneoog
Post by arneoog » Tue Oct 10, 2006 1:58 am
Superb, Nick! :D
It's rendering quite fast 8)
8bstudio
Re: Indigo v0.6 test 4
Post by 8bstudio » Tue Oct 10, 2006 2:04 am
Ono-Sendai wrote:v0.6 test 4:
Changelog:
Many thanks to great Ono-Sendai!!! :D :D :D
tungee
Post by tungee » Tue Oct 10, 2006 5:35 am
Master !
Thx !
Ono!
Camox
Post by Camox » Tue Oct 10, 2006 5:58 am
Thank you very much Master Ono ! :D
Marcofly
Post by Marcofly » Tue Oct 10, 2006 7:00 am
Thanks a lot!!
Ciao!!
:D
Xman
Post by Xman » Tue Oct 10, 2006 1:16 pm
Thanks Nick :D
´'`\_(ò_Ó)_/´'`
Post by Zom-B » Tue Oct 10, 2006 2:34 pm
Something smells fishy here:
After intodruced in v0.62 the emitters for RGB Light could be colored by other Emitters.
This Effect became stronger and stronger by each Test version :?
Interesting too:
In the 0.64 rendering, the red light affect the green & blue one, the blue affect the red & green,
but the green RGB Light ONLY affect the red emitter, and doesn't touch the blue one??!?
*** EDIT ***
This strange color bleeding seems to be rainhards fault!
v0.62
v0.63
v0.64
Check this Threadfor File & Info
BTW
Somehow the v0.62 is much faster than 0.63, and also 0.64 in this project :?
