Indigo Renderer 2.4.3 Released
Re: Indigo Renderer 2.4.3 Released
Post by fused » Tue Apr 20, 2010 11:58 pm
pixie wrote:Could you elaborate on which kind of tests you've made?
Just rendered the same scene with both versions and calculated the increase in samples/second.
It's not some kind of perceptual convergence improvement, its a blunt speedup.
forgeflow
Post by forgeflow » Wed Apr 21, 2010 1:56 am
Waiting patiently for a Mac build. :)
ritter
Post by ritter » Wed Apr 21, 2010 2:12 am
forgeflow wrote:Waiting patiently for a Mac build. :)
Me too!
Jambert
Post by Jambert » Wed Apr 21, 2010 2:32 am
20% gpu desable :)!!!
waiting for a linux build too ;)
Post by StompinTom » Wed Apr 21, 2010 2:34 am
Indigo 2.4.3 is crashing just before it starts rendering, after it's loaded everything, done subdivisions. I have a suspicion that it may have to do with subdivision. Other scenes seemed to load and render fine, as did this one before I started using subdivision.
Testing...
Post by Zom-B » Wed Apr 21, 2010 2:38 am
StompinTom wrote:Indigo 2.4.3 is crashing just before it starts rendering, after it's loaded everything, done subdivisions. I have a suspicion that it may have to do with subdivision. Other scenes seemed to load and render fine, as did this one before I started using subdivision.
Yes, I had such an issue too! I send a example crash file to fused for investigation...
Post by StompinTom » Wed Apr 21, 2010 3:13 am
Yep! The scene works perfectly fine without subdivision.
ENSLAVER
Post by ENSLAVER » Wed Apr 21, 2010 3:40 am
On that note I get a crash with a displacement that has high subdiv AND a diffuse map, take away diffuse it's fine. (x64)
Post by Zom-B » Wed Apr 21, 2010 3:50 am
ENSLAVER wrote:On that note I get a crash with a displacement that has high subdiv AND a diffuse map, take away diffuse it's fine. (x64)
I also can confirm this issue...
Post by Zom-B » Wed Apr 21, 2010 4:16 am
fused wrote:Nick mentioned today that Indigo 2.4 should be quite a bit faster than 2.2 so i benchmarked it.
Turns out that on my Core 2 Duo it is 20% faster. 8)
Well I don't think so Glare... at least not if you use subdiv a lot :(
I found out that my testrenders for towel closeups with high subdiv and displacement where rendering very slow!
This "benchmark" is done with this scene, with a lot of subdiv around the scene...
This speed problem maybe also related to the crashes mentioned above.
btw: why does the news site tell something about a speedup of 20-30% ??? Any proofs for this???
Post by fused » Wed Apr 21, 2010 9:49 am
well depends on your hardware. nick said 30% on his i7 but on my core 2 duo it was only 20. i tested the pins sample scene.
Godzilla
Post by Godzilla » Wed Apr 21, 2010 12:18 pm
So, is there any reason why Zom-B's scene is slower?
Post by lycium » Wed Apr 21, 2010 12:24 pm
I think there are currently some issues with displacement and bump mapping, there was an example shown earlier with incorrect results.
Post by Zom-B » Wed Apr 21, 2010 2:34 pm
lycium wrote:I think there are currently some issues with displacement and bump mapping, there was an example shown earlier with incorrect results.
Just tested Bvh vs Kd-tree for a closeup of a subdiv displaced towel
kd-Tree: 138k s/s
BVH: 94k s/s
Post by suvakas » Wed Apr 21, 2010 5:28 pm
Zom-B wrote: kd-Tree: 138k s/s
BVH: 94k s/s
I belive this is normal. BVH loads faster, but renders slower than KD, I think.
