Indigo slave licensing question...
7 posts • Page 1 of 1
Post by Zom-B » Thu Jul 02, 2009 9:32 am
Hey Ben...
I'm seriously interested in finally getting a license :)
But I still got a question about licensing:
that the master license is restricted to the "main machine" is quite ok, and obvious !
But how about the slave licensing? Is the slave license connected to the master,
so that after 2 (random) Indigo 2.x slaves connected the cue is closed (just like for C4D Netrender)
or is it the evil way to hook the slave license to the hardware of a slave too???
Since Indigo is interesting for some commercial work, where I got mostly (Internet) access (via Hamachi) to two 8 core Mac's, I would like to use this two slave licenses for them..... BUT during nonprofit Jobs I would like to use my home network or some friends over the Internet too!!!
So am I lucky, and the slave licensing is dynamic (like for C4D), or how does it work exactly?
Thanks in advance :)
benn
Re: Indigo slave licensing question...
Post by benn » Thu Jul 02, 2009 12:01 pm
Guten Tag Herr ZomB!
Der licence fur Indigo ist...
The licencing system for Indigo specifies a hardware ID for each render slave, so you need to choose two renderslaves that you want to run Indigo on, and install Indigo on those. I hadn't heard of that dynamic licencing idea before - so you're saying that you install indigo on your pc, and it has 1 full licence and two dynamic licence it can use to fully-enable any installed indigo slave?
That's a cool idea - I'll discuss it with Ono when he comes in.
Ben
Post by Zom-B » Thu Jul 02, 2009 9:40 pm
Yes, the Idea is to have "licensing check" running only on the master Hardware, so the first two clients that join are accepted a third, fourth etc. would be blocked. This system is more flexible for the user.
I don't know about the (cracking) security of this system... basically the free 2.x demo could be used as netrender without restriction (and no ISI saving on HDD!).
Post by Zom-B » Fri Aug 07, 2009 3:04 am
Just to push this interesting topic, any news here???
I read somewhere about your plans to get away from the Mac Address...
Post by OnoSendai » Fri Aug 07, 2009 11:42 am
We may do the licensing on the server only at some point, but not just now sorry.
Post by Zom-B » Fri Aug 07, 2009 8:45 pm
No problem with the timing, the general info is enough for me atm :)
Post by zeitmeister » Sat Aug 08, 2009 12:31 am
I totally agree with ZomB.
The slave limitation should be that way, that the master looks up how many node licenses are bought/allowed and then catch all nodes running automatically.
