178,29% adaptive_displacement_shader_test
103,39% airy_disc_test
066,95% albedo_shader_test
100,01% background_exit_portal_test
183,33% background_material_test
185,71% blend_material_shader_test
097,16% bokeh_test
086,73% bumpmap_test
103,62% caustic_participating_media_test
104,27% colour_test
124,60% curve_subdivision_test
116,98% diffuse_transmitter_test
081,21% dispersive_block_test
102,26% displacement_shader_test
082,60% emitting_material_test
105,91% exit_portal_test
097,25% extinction_test
087,33% glossy_glass_test
099,46% instanced_emitter_test
119,69% internal_mesh_test
099,72% layer_blending_test
096,76% luminous_flux_test
102,42% meshlight_test2
098,31% normal_smoothing_test
099,05% null_material_sphere_test
108,91% oren_nayar_test
096,90% patterned_frosted_glass_test2
106,54% phong_energy_loss_test
099,60% procedural_bump_test
103,23% regular_tabulated_spectrum_test
100,25% simple_bump_test
115,12% simple_test
104,28% sky_background_test
099,17% specular_normal_smoothing_test
100,64% sphere_bump_test
104,97% sss_energy_loss_test
101,65% subdivision_quad_test
124,00% subdivision_uv_test
104,42% sun_bump_test
107,44% texture_test
086,84% airy_disc_test
098,98% antialias_test
101,15% background_luminance_test
104,75% binary_mesh_test
082,17% blend_material_test
081,62% box_emitter_test
098,91% bump_displacement_test
103,48% checker_antialias_test
084,44% cornellbox_jotero
076,98% diffraction_test
093,93% dispersion_test
080,61% dispersive_medium_test
106,34% dof_test
105,22% empty
098,53% exponent_map_test
116,74% glossy_normal_smoothing_test
102,91% instancing_test
099,28% ior_test
083,80% luminance_test
096,15% meshlight_test
119,20% null_blend_test
105,05% obj_test
097,55% patterned_frosted_glass_test
102,46% phong_cornell_box_test
085,56% phong_test
121,03% precedence_test
106,25% quad_displacement_test
123,04% shift_lens_test
098,24% simple_plane_test
097,99% skin_test
086,42% sky_mesh_emitter_mix_test
098,12% specular_sphere_test
122,80% sss_block_test
101,22% sss_test2
103,11% subdivision_test
101,21% sunny_16_test
087,25% sun_glare_test
101,19% translucent_energy_test
103,34% Overall
Failed tests
phong_test_4
metal_test
globe_test
terrain_test
textured_emitter_test
