Rendering nodes for Indigo.
8 posts • Page 1 of 1
Godzilla
Post by Godzilla » Sun Aug 09, 2009 5:12 pm
I took some time to put together these computer packages for those of us who have 2 node licenses sitting around and are considering buying a node to help out with rendering, but don't know very much about computer hardware. :wink:
Low-End ~ $250/ €175
CPU: Intel Pentium E5200 2.5 Ghz Dual-core
Motherboard: ECS Micro ATX
HDD: WD Caviar 80GB
Power Supply:Logisys 350W Micro ATX
RAM:OCZ 2 GB 667MHz
Case: CM Centurion Micro ATX
Average ~ $400/ €280
CPU: AMD Phenom II X4 3.0 Ghz
Motherboard: MSI MicroATX
HDD: WD Caviar 80GB
RAM: 2x Patriot 2GB DDR2 800 Mhz
High-End ~ $1250/ €880
CPU:Intel i7 950 3.06 GHz
Motherboard: EVGA i7 Micro ATX
HDD: WD Caviar 160GB
Power Supply:Athena Power 550W Micro ATX
RAM:OCZ Gold 12 GB 1600 MHz
I Just won the lottery. ~ $15000/ €10500
CPU:4x AMD Opteron 2.6 Ghz 6-core processor
Motherboard: TYAN Quad-Opteron
HDD: 512 GB SSD disk
Power Supply:PC Power & Cooling 1200W
RAM:32x 4Gb G Skill 800 Mhz DDR2 RAM
Case: No Idea where you would find a MEB form factor case.. this motherboard is huge.
So, this node has 128 GB RAM, 4 Processors, 24 cores, and 62 Ghz total processing power on ONE motherboard.
I'm pretty sure all of these components would work together, let me know if I made any mistakes.
SaphireS
Re: Rendering nodes for Indigo.
Post by SaphireS » Sun Aug 09, 2009 11:39 pm
Thank you very much!
Your ad here!
WytRaven
Post by WytRaven » Sun Aug 09, 2009 11:50 pm
Thx for sharing your research Zilla.
Post by Zom-B » Mon Aug 10, 2009 12:14 am
I rather like the approach to have ONE Power Supply for many Mainboards like here
(Sorry German Site, but images & video are quite self explaining)
You save a LOT of Power, Room and money by this!
Instead of a HDD you also can boot from a cheap USB drive, that saves Power, Room and money too ;-)
For me most important thing for a slave would also be the "future compatibility" to upcomming CPUs.
By this you can boost your render slaves after a few years and investing some money, without buying everything new!
Godzilla
Post by Godzilla » Wed Aug 19, 2009 5:20 pm
New build added..
I was bored.
Jambert
Post by Jambert » Wed Aug 19, 2009 8:07 pm
Godzilla wrote:I Just won the lottery. ~ $15000/ €10500
:lol: it's crazy
does it exist for i7?
Godzilla
Post by Godzilla » Thu Aug 20, 2009 12:40 am
Im sure some company is working on it. :wink: But currently the most i7's you can have is 2.
Post by PureSpider » Thu Aug 20, 2009 2:48 am
Cornholio! 10500€! :shock:
