[REQ] Animated Textures
I searched the forums and couldn't find any reference of such a thing being in Indigo...
Is this possible? Or is there some way that it could be done through Blendigo by just outputting a different texture map at each frame when you load a whole sequence of textures? I'm thinking of all sorts of things, but primarily I need an animated screen/display on an object.
- zeitmeister
Re: [REQ] Animated Textures
+1
If you are using image sequences for animation, support for using them in general animation shouldn't be a solvable task for the Exporter writers...
But please don't get the idea to support video files as texture in Indigo dear Glare... there are way more interesting requests
- pixie
I could bet that cindigo does it alreadyZomB wrote:If you are using image sequences for animation, support for using them in general animation shouldn't be a solvable task for the Exporter writers...
depends - if you put the video texture in a shader it doespixie wrote:I could bet that cindigo does it alreadyZomB wrote:If you are using image sequences for animation, support for using them in general animation shouldn't be a solvable task for the Exporter writers...
- zeitmeister
Show. Us.
Please!
Please!
ok, it doesnt work. 2 reasons:zeitmeister wrote:Show. Us.
Please!
1) baked texture is always overridden in the next frame
2) bake document always renders frame 0
fixing...
heh, fixed!
that was a simple fix
rendering...
rendering...
animated textures with cindigo:
http://www.vimeo.com/7336641
used zed_pmd's layer blending video, hope that ok for you, zed
will be possible in the next version of cindigo.
- Borgleader
Haha that's pretty coolfused wrote:animated textures with cindigo:
- zeitmeister
T.H.E. M.A.S.T.E.R. O.F. A.W.E.S.O.M.E.N.E.S.S. S.T.R.I.K.E.D. A.G.A.I.N.!
Benn, please add it to blendigo
<3 x 10000000
