ange
by ange » Thu May 17, 2012 11:04 am
I recently installed the new updates for Indigo RT (3.2.13) & Skindigo (3.2.12) for a Mac Pro desktop (10.6.
. I'm using Sketchup Pro 8.x.
As you can see in the two attached screen shots, all of the input fields in the Skindigo Render & Material Editor are all blacked out. I tried re-installing both Indigo RT & Skindigo with no change.
Any solutions or ideas?
Thanks much
-ange
Voytech
by Voytech » Fri May 18, 2012 6:02 am
Confirmed here as well. Black background on the input fields. Everything works and if you highlight the field you'll see there are numbers there but obviously this is less than ideal.
My Setup is the same except I'm on Lion (10.7)
Voytech
by Voytech » Wed May 23, 2012 1:41 am
Just a bump to make sure Whaat sees it.
by Whaat » Wed May 23, 2012 1:52 am
Sorry guys,
I have noted this thread and am looking into the issue.
Can you confirm that older versions of SkIndigo do not have this issue?
Voytech
by Voytech » Wed May 23, 2012 5:50 am
I'll check at home and let you know. I think I still have the previous release there.
Voytech
by Voytech » Wed May 23, 2012 8:05 am
One more thing....
Just installed Make Fur plugin. Its fields are also black.
ange
by ange » Thu May 24, 2012 8:09 am
I did not have this issue with any of the 2.x releases. Can't say for sure about any of the 3.x releases.
I do not have any of the previous versions to try, but I would be happy to test out if I could get an older version.
Thanks so much for your help.
Whaat wrote:Sorry guys,
by Whaat » Fri May 25, 2012 3:18 am
The issue is apparently caused by the latest Safari update
and affects all plugins that use webdialogs.
I will see if I can provide a fix in the next release but I'm not sure when that will be. Try to revert to an older version of Safari. If I can find another workaround, I will post it here.
