It could be good idea to choice where you want to save downloaded materials (you can specifies path as default and change it for every project), thanks to this you want have a problem with moving your scene to other computer. Of course you can always give: save as but it doesn't work every time as it should. Sometimes indigo is calling for materials from C:\user\xxx\appdata\local\... and so on.
example:
C:\projects\|
..................|_projectOne
...................................|_materialsDB
...................................|_blends
...................................|_maps
..................|_projectTwo
and so on.
What do you think about it?
Also login to Material DB should be able from Material editor (if you have license it should be automatically if not there should be some simple form, so you don't kneed to open browse).
saving downloaded materials and uploading
