h
yonosoy
Re: h
Post by yonosoy » Wed Jan 29, 2020 10:05 am
Ornatrix test. It is able to export the fur as a mesh, but it is very heavy.
A draft of furry over a human head.
"... the hamster don't see the wheel, and this wasn't said before." (yoS eidaN "el Olvidao")
https://www.instagram.com/yonosoy_nada/
yonosoy
Re: h
Post by yonosoy » Sat Feb 01, 2020 2:41 am
Hard; 16700 spp.
yonosoy
Re: h
Post by yonosoy » Sat Feb 01, 2020 9:10 am
Then, at last, the translation of what was published from the congress in pdf (google translation, sorry).
And the first drawing of an Amazon by "el Desvelao".
yonosoy
Re: h
Post by yonosoy » Fri Feb 07, 2020 11:39 pm
The dark side of the Moon (Indigo´s version).
Conversations.
yonosoy
Re: h
Post by yonosoy » Mon Feb 10, 2020 6:20 am
I will try to finish it with what I call GeoSun ...
ISL exercise.
Re: h
Post by OnoSendai » Tue Feb 11, 2020 2:38 am
Love this one!
yonosoy
Re: h
Post by yonosoy » Sat Feb 15, 2020 1:18 pm
Thank you very much.
Only feeding your baby.
Optics + mie.
Re: h
Post by lycium » Sat Feb 15, 2020 1:23 pm
This is some of the greatest rendering porn on the internet :O Amazing job as always!
yonosoy
Re: h
Post by yonosoy » Sat Feb 15, 2020 1:29 pm
Optics + atmosphere + GeoSun.
The interior paths are really difficult. Working on it.
yonosoy
Re: h
Post by yonosoy » Tue Feb 18, 2020 6:03 am
Witnesses test. 27 h.
A multi-instance cloner over the particles, not TP geometry. I forgot the random effector.
yonosoy
Re: h
Post by yonosoy » Fri Feb 21, 2020 10:08 am
Exploring the movement of Hypertime. 1000 spp, 12 minutes.
I suspect that can´t go over this time for a frame of the animation.
For do this, two timelines are needed. As this is not possible yet, I must export a frame of the movement and copy/paste a whole camera exportation.
Doesn't it make you think that something so simple develops such complex and beautiful images?
yonosoy
Re: h
Post by yonosoy » Sat Feb 22, 2020 1:04 pm
3D Scan Store. Looks promising. Only diffuse map to work.
Fast SSS skin, Glossy hair. 8 minutes 200, spp.
Sorry but I erased the serie... This one is enough.
yonosoy
Re: h
Post by yonosoy » Thu Feb 27, 2020 6:09 am
Working on the first of the serie.
Will play one or two days more...
Stage 2, OK. To wait until convergence.
Will be the first working mie cumulus earth layer. This helps a lot in realism.
1 Universal vacuum (with his own contradictions!). Perfect sphere. Radius 1e140. Precedence 2.
2 GeoSun (position, distance, radius, extra-atmospheric emission spectrum). Perfect sphere. Precedence 3.
3 Atmosphere. Perfect sphere. Precedence 4.
4 Clouds sphere. Perfect sphere. Precedence 5.
5 Inner Atmosphere. Perfect sphere. Precedence 6.
6 Landscape 42 x 42 km (we are seeing about 6 x 6, but the reflections on the witnesses must be covered...).
7 Earth sphere. Perfect sphere. Precedence 15 (a blend between a phong and a specular with blended factor 0.0).
Then, the camera and the witnesses.
Want to try optics for the serie, but the camera must be on 0,0,0 position to work (around 50 meters radius of deviation accepted). More work. Also another models of objectives are required. A less conceptual diaphragm, ...
Will see... a bite by the moment.
Subdivision + displacement (EXR).
4K downsized to 25%, 5 hours.
Will post an HD solution in the next days under this one.
yonosoy
Re: h
Post by yonosoy » Sun Mar 01, 2020 4:53 pm
Based on a serie called "Masks" (don´t remember the photographer, he works in B/W).
yonosoy
Re: h
Post by yonosoy » Sun Mar 01, 2020 6:21 pm
Subdivision and displacement.
