Can't get light bulb to work
- Doug Armand
Re: Can't get light bulb to work
Did you apply the emitter material to the bulb itself?
The problem seems to be if you want a clear bulb and lit filament.
Doug
Doug Armand
Doug Armand
- Doug Armand
Transparent but frosted? not clear glass.
Works well though if you are after a opalescent bulb - personally I like it - may use it myself
Left pane of glass with your material - right pane with clear glass.
Edited to update image
- Lightbulb.jpg (93.54 KiB) Viewed 3064 times
Doug
Doug Armand
Doug Armand
turning bidir and metro off gives better result:
- test.jpg (130.39 KiB) Viewed 3070 times
- Doug Armand
I quess it's the quadruple pass through glass with bidir that's messing things up. I also rendered a very small sample up to like 20 000 spp with those on and it eventually did clear up...
- Doug Armand
Looks kinda funky with aperture diffraction on
BDir and Metro off
BDir and Metro off
- Lightbulb.jpg (141.31 KiB) Viewed 3054 times
Doug
Doug Armand
Doug Armand
- Polinalkrimizei
Merry christmas?!
- Borgleader
Thanks I'll look into all possible avenues Also,merry xmas
- Polinalkrimizei
Everything you guys say makes a lot of sense but I still don't get it:
Even though the model is not a 100% perfect (modifiers not applied, too big, glass to thick...) this SHOULD work!
I assigned other materials (one of the famous schott db without cauchy b to be precise) and it works actually (just need higher ev adjust and a little higher iso). So it seems to be a material problem that I don't get.
First picture is everything untouched, exept the glass material.
Second picture is with inner faces of the glass removed and ghost glass mat applied.
- Light Bulb Schott.png (408.73 KiB) Viewed 3035 times
- Light bulb ghost glass.png (370.72 KiB) Viewed 3027 times
- Polinalkrimizei
I made two more tests and I think the answer is: Your glass ist just way too thick. If you just remove the inner faces of the bulb, your material works fine
Or just scale everything to real-world-size.
- Borgleader
I'm geting a "matrix is not invertible" error now >.>
I know it's less accurate but it looks better to me if I delete the glass around the filament but leave the bulb - clears up faster.
Here are my renders:
- lightbulb.jpg (101.73 KiB) Viewed 3010 times
And without the glass:
- bulbless.png (372.68 KiB) Viewed 2998 times
