Another question:
I still get the unexpected element 'layer' indigo error when using the Indigo Shader choosing the phong material.
I'm using the latest svn revision on Maya 2009 Win32.
Unexpected element layer in element phong
Completely new? K, this will explain all those errors while I've directly changed the tags in the igs file.
CTZn, how about I commit my changes in mti_ExportModuleShaders.mel directly via svn?
I did not change everything regarding to the phong section, but so I would know if I did the things i've done correctly.
Thanks Ono, I was suspecting that (I think fused told me actually), but fearing it also. That means a deep code reformating has to be done, not really out of my scope but I'm not used in planning that big things. Oh, and that could take ages with me
Hellstorm: well, if this has to be a collaborative work, I'd like us to discuss the what and the how before everything, so we keep in sync. Especially we must have the same idea on what we are doing, or at least confront these conceptions, no ? I'm willing to have a sidekick, but I'm a bit shy in the begining You certainly have more experience in mel than I do ^^
How many lines did you change *freightened* ? what did you change if I may ask, can you show the lines here plz ? Since these parts are going to be deeply reformated, is it safe to consider it as a temp fix ?
Sorry if I sound a bit conservative, you coding is a new thing to me
I've just finished graphing the export process, actual (r275) state is between 20 and 25% done on shaders export steps. I'd like to discuss that with other devs, I wonder how. Maybe GPU could be helpfull here, with its white board (you can see what others are drawing).
edit: no, we'll discuss it here that's better. I'm pseudo-coding now, if the result is meaningfull enough I'll post that.
