Cindigo 1.1.10 Beta
Juniorsatan
Post by Juniorsatan » Thu Sep 11, 2008 6:22 am
carsten_fokuspunkt wrote:Thanx a lot for this version, fused. i just played around with multi-materials on a mesh via selection-tag and this is soooo cool.
+1
really comfortable :)
Post by pixie » Thu Sep 11, 2008 9:49 pm
Sayris
Post by Sayris » Fri Sep 12, 2008 7:50 am
big thx :D
Rafaello
Post by Rafaello » Fri Sep 12, 2008 9:01 am
Hello, I'm new with Cindigo and the x64 version of Cinema R10.5 doesn't recognize the exporter, The x86 version doesn't have a problem but I have to work with x64 at home, can you help me to make x64 recognize the plugin? please.
I work with Windows XP Pro 64 and Vista home premium 64 too.
thank's a lot
Post by Zom-B » Fri Sep 12, 2008 9:28 am
Hey Raf...
Simply use the 32bit version for exporting to Indigo :roll:
Or are your c4d files realy soooooo heavy that they crash the 32bit version?
Rafaello
Post by Rafaello » Sat Sep 13, 2008 6:10 am
Hi, thanks, I was working yesterday with the 32 version and had no problem with Cindigo, so now I have to learn how to use both Cinema and Cindigo, that leads to the next cuestion: Where can I find tutos for Cinema and Cindigo?, I worked before with 3ds max but find that Cinema is very friendly so I want to change to it.
Post by Zom-B » Sun Sep 14, 2008 2:24 am
Check the first post for a cindigo tutorial link!
For basic C4D Tutorials check this out...
cinema
Post by cinema » Sun Sep 14, 2008 8:05 pm
Thank you very much Fused! :o
Rafaello
Post by Rafaello » Tue Sep 16, 2008 6:44 am
Thank's for the info ZomB
Onfame
Post by Onfame » Mon Oct 27, 2008 10:06 am
I don´t know if i am right or it is my fault, but i get an error every time i convert a cinema4d material with an active "Leucht Kanal" (don´t know what it is callesd in english, maybe illumination or luminance channel). I can convert the material but when i start Indigo, then an error appears. Also Cindigo doesn´t seem to use textures for the light layers, means i have manually write into the igs:
<emission>
<texture> ...
And i would thank you for an explanation for the camera tonemappig (when i use the "dscs315.txt" as camera typ, my renders are always black).
(Hope my english isn´t so bad and understandable :) )
Post by PureSpider » Mon Oct 27, 2008 11:12 am
For camera tonemapping you need to setup correct ISO values and so on... Go inform yourself what a real cam would use and go for those values ;)
Onfame
Post by Onfame » Mon Oct 27, 2008 11:15 am
hmm but i have to give Cindigo a file, so i tried the one from the preview scene, and no matter what i change in the "Film ISO" in indigo, the picture is allways black..., so i just wonder where can i get other camera files?
Post by PureSpider » Mon Oct 27, 2008 11:54 am
There are no other atm...
The file can also be found in indigo's data dir...
Just try to mess around with ISO and EV values.
Onfame
Post by Onfame » Mon Oct 27, 2008 12:02 pm
Okay i will try and post my results tomorrow in another thread :) Have to sleep now :(
Post by fused » Mon Oct 27, 2008 7:17 pm
Onfame:
try to use a longer exposure.
actually, cindigo uses textures set in the luminance channel, but only if emission is activated in the mat helper - at least it should.
