Hello, I'm really too lazy to write a full lenghted post but there is the next version of MtI, no installer available this time:
MayaToIndigo_1.1.7_beta1.zip
The exporter only introduces rgb emission and layers, just enough to play with light layering system of 1.1.7. Also you will find a new helper, the Indigo Palette, wich is accessible through an icon in the main UI. Beware this tool is incomplete, read mtiObjectEditor header for some tips.
That version of indigoShader will not be compatible with previous versions of Indigo, althought you can still use usual Maya shaders, but in turn they do not support emission/layering (ah well you can use them with previous Indigo versions).
Usual warning: I'm the worst coder interventing lastly on MtI, do not ever think about using MtI in a production environment unless you can take that responsability on your own. You are not a kid anyway
Enjoy and ask !
MtI for 1.1.7 beta 1 (obsolete versioning)
Cheers CTZn.
Can I make a request that you keep careful backups of your MtI code for the time being? My SVN/web/everything server has just lost it's HD and will be offline until I can replace it.
Not much data lost, as I do automatic weekly backups, but I may have lost your last SVN commit.
I'll make sure I tell you when I have everything operational again.
Ah nice, it's the latest, with the new icon - wich is quite off - (doh). See, I had a peak of fever, didn't do anything since then...
However I have made the palette's code easier to update with new controls, plus few ui arrangement (regrouped the so called "advanced" into "shortcuts).
Was the Indigo Palette included in last distro ? arg I'm getting old... it should make life somehow easier when it comes to edit Indigo related objects in Maya.
