Indigo 1.1.6
Indigo 1.1.6
NOTE: this is a *test / beta* release. If you want a build that works smoothly with exporters, get the last stable release from the main download page in the download menu.
windows 32 bit:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
windows 64 bit:
Changelog:
1.1.6
* disabled old-stlye glare and bloom
* materials can now emit light
* added EXR as supported texture format.
* network rendering now transfers (packed) scene file over network
* updated GUI: integrated interactive tonemapping, open/close scene, pause/resume render
* energy loss stuff is only computed if phong exponent param is a constant parameter.
* added shaders
* layer blending
I'll start slowly adding explanations of how to use the various new things.
In the mean time, check out layer_blending_test.igs for an example of layer blending, and albedo_shader_test.igs for a shader example.
windows 32 bit:
windows 64 bit:
Changelog:
1.1.6
* added shaders
* layer blending
Ono, I tried to render the scene I rendered in 1.1.5:
http://www.indigorenderer.com/joomla/fo ... php?t=4600
and the glass is black so far. I use MTL. Any clue? Nice update. One suggestion numeric input would be useful.
good progress ono -first comments-
stop and pause dont seem to work here and the Indigo icon is missing from the .exe?
I would appreciate if the bottom left panel was narrowed up to just after the layer7 so you can see the render progress commentary without pulling the window right out to a widescreen format
Vegetable Navaratan Korma
Lamb Madras
Vegetable Platter for two
Keema Naan
Plain Naan
EDIT: very cool so far regards 'realtime' adjustments
EDIT2: your emitting_material_test example has a wrong texture name or is missing from the folder.
EDIT3: no.2 edit also applies to flux and luminance .igs as well
Lamb Madras
Keema Naan
Plain Naan
Users browsing this forum: No registered users and 57 guests
