A car and a sunny day... (animation added on page 2)
- kwistenbiebel
- Borgleader
Brilliant stuff! You have to start using Indigo displacement! It's really easy. Try setting your max subdivisions to 9 and then your displacement map 'gain' (b-value) to about 0.1 for starters. Then, keep tweaking the gain until you are satisfied with the depth of the displacement.
Here's a tip for quick tests: Just select the stone material and 'render selection only'.
- kwistenbiebel
Thanks Dale, for bringing displacement up.Whaat wrote:Brilliant stuff! You have to start using Indigo displacement! It's really easy. Try setting your max subdivisions to 9 and then your displacement map 'gain' (b-value) to about 0.1 for starters. Then, keep tweaking the gain until you are satisfied with the depth of the displacement.
I kind of got scared by its complexity when I tried it some time ago (I returned to Indigo 1.0.9 after my first tests).
But with your hints, I am definitely going to try it again.
- kwistenbiebel
- PureSpider
- kwistenbiebel
I wanted to update this thread with a little animation:
http://www.youtube.com/watch?v=dDPQmdN9h0M&fmt=18
Unfortunately the DOF was not animated.
It should have shifted focal point between big car, RC car and RC itself, but the Skindigo plugin doesn't seem to support that.
- kwistenbiebel
Users browsing this forum: No registered users and 61 guests
