Another small release, just fixing bugs and tweaking the new embedded mesh format.
32 bit:
http://www.indigorenderer.com/joomla/in ... &Itemid=62
changelog:
1.1.3
* changed embedded_2 format yet again
* changed default name of pigm/pigs in save dialog to be same as igm/igs
* --unpack now doesn't overwrite existing files, and can unpack to absolute paths
* packing packs displacement maps now
* fixed crash on exposition of UV set without providing actual UV data.
* fixed --unpack to make subdirs properly
* new version 2 of IGI format: added render time.
* total render time and samples/sec now displayed correctly when a render is resumed.
* added command line tonemapping with the --tonemap option
* reenabled optional specification of vertex shading normals in the scene file
* reenabled fatal error on non unit-length normals.
* added merge_vertices_with_same_pos_and_normal option for mesh, defaults to true.
* removed step_null_blend option, added step_blend option for blend materials.
The embedded_2 format looks like:
<mesh>
<name>mesh2</name>
<normal_smoothing>true</normal_smoothing>
<embedded_2>
<expose_uv_set>
<index>0</index>
<name>albedo</name>
</expose_uv_set>
<used_material_name>mat_a</used_material_name>
<used_material_name>mat_b</used_material_name>
<v p="-1.5 0 0" />
<v p="-1.5 0 2" />
<v p="1.5 0 2" />
<v p="1.5 0 0" />
<uvs uv0="0 0" uv1="0 0" />
<uvs uv0="0 1" uv1="0 100" />
<uvs uv0="1 1" uv1="100 0" />
<uvs uv0="1 0" uv1="100 100" />
<t v="0 2 1" uv="0 2 1" m="0"/> <!-- this triangle uses mat_a -->
<t v="0 3 2" uv="0 3 2" m="1"/> <!-- this triangle uses mat_b -->
</embedded_2>
</mesh>
