Indigo v1.0.9 for Linux
Grimm
Post by Grimm » Mon Apr 07, 2008 11:02 am
Hi Ono,
Thank you, thank you for the linux version!! :D
Unfortunately when I run the 64 bit version I get this error. I did have to install wxGTK to get it to even try to start. It appears that the versions are the same, so I'm not sure what the problem could be?!? Thanks,
indigo_x64_linux_v1.0.9]$ ./indigo
./indigo: Symbol `_ZTV10wxClientDC' has different size in shared object, consider re-linking
Fatal Error: Mismatch between the program and library build versions detected.
The library used 2.8 (no debug,Unicode,compiler with C++ ABI 1002,wx containers,compatible with 2.4,compatible with 2.6),
and your program used 2.8 (no debug,Unicode,compiler with C++ ABI 1002,wx containers,compatible with 2.6).
Aborted
indigo_console appears to run ok.
Grimm
jurasek
Post by jurasek » Mon Apr 07, 2008 12:26 pm
Ono, what version of OpenEXR that build needs?
./indigo_console test.igs
Indigo Renderer v1.0.9, Linux 64-bit Release build.
Using base Indigo directory path '.'.
Scene file path: 'test.igs'
Using working directory path ''.
Loading Scene 'test.igs'...
Using Reinhard tone mapping with pre_scale=4.000000, post_scale=1.200000, burn=6.000000
Loading lat/long env map 'test.exr'...
./indigo_console: symbol lookup error: ./indigo_console: undefined symbol: _ZN3Imf13RgbaInputFileC1EPKc
greetz,
jur
Post by OnoSendai » Mon Apr 07, 2008 10:16 pm
Jur: Beats me, whatever version of libopenexr-dev on Ubuntu 7.04 is.
dougal2
Post by dougal2 » Mon Apr 07, 2008 11:02 pm
$ dpkg -l libopenexr-dev
$ dpkg -l openexr
should show you what is installed on your machines.
jurasek
Post by jurasek » Mon Apr 07, 2008 11:17 pm
Propably compiled with 1.2.something, with my 1.6.1 here dosen't work :(
greetz,
jur
Phr0stByte
Post by Phr0stByte » Mon Apr 07, 2008 11:25 pm
dougal2
So everything is cool for you on Hardy? I am also running Hardy and am itching to try this when I get home (working on a new model in Maya, I am not dead - just doing a complicated model...).
dougal2
Post by dougal2 » Mon Apr 07, 2008 11:30 pm
Yeah it worked fine, no problems at all. I'm at work right now, but if you want to know the exact version of whatever libraries i have installed, I can find out and tell you later.
Phr0stByte
Post by Phr0stByte » Mon Apr 07, 2008 11:33 pm
dougal2
Havnt tried it yet, but hopefully ther will be no issues. Have been deep in Mental Ray for a while, so it would be nice to do an Indigo render again. I am modeling a car right now - maybe I can get I nice car paint from the new mat combos that are possible....
vmuriel
Post by vmuriel » Tue Apr 08, 2008 7:07 am
Thanks for linux 64 bits release.
indigo and indigo_console works excellent for early tests.
If you get gtk error, install libwxgtk2.8-0 (Ubuntu 7.10 - the Gutsy Gibbon).
exr work fine with standard Ubuntu 7.10 version,
libopenexr2c2a
1.2.2.4.3ubuntu2
joegiampaoli
Post by joegiampaoli » Tue Apr 08, 2008 3:53 pm
Ono, Thank you so much, works perfectly well here with me @ 32bit I don't use the GTK front end much, always console, but its all working fine, and resumes with no errors.
Thanks again! :D
Joe Giampaoli
My Indigo Gallery
afecelis
Post by afecelis » Wed Apr 09, 2008 1:29 pm
Thanks Master Ono. The native Linux builds rock!!! :D
regards,
Alvaro
Users browsing this forum: No registered users and 52 guests
