tinted, frosted glass
6 posts • Page 1 of 1
kubabuk
Post by kubabuk » Fri Apr 04, 2008 11:52 pm
Hi all,
I am having problems with making a tinted frosted glass material? Should I create glossy transparent material and as a medium use Medium basic? I tried changing a color of a absorption coefficient value but it does not influence the color at all.
Speaking of a glass, there is another effects I am trying to recreate. If you look at the edge of a thin glass pane it gets very dark. It is I suppose because of some absorption process going on. How can I control this effect and how do I contrlo the color of the absorbtion. Is absorption coefficientresponsible for that and should I use glossy transparent material for that?
thank you
kuba
Gog
Post by Gog » Sat Apr 05, 2008 12:51 am
You may consider this a cheat, but I find a very fine noise in the bump channel the quickest way to create a frosted look. so make a coloured glass of the tint you want then apply the bump....
Olis
Post by Olis » Sat Apr 05, 2008 8:06 am
Sure you can make tinted frosted glass without using a bumpmap:
The thickness of the glass pane is 1 cm.
JDA
Post by JDA » Sat Apr 05, 2008 10:56 am
Nice example Olis!
Olis
Post by Olis » Sat Apr 05, 2008 12:25 pm
Thanks! :D
alexmeyer
Post by alexmeyer » Sun Apr 06, 2008 7:16 am
That is a really cool looking example, very nice.
Yet another way (though I think yours still looks very cool, just including this for completeness) is to use a blend of a diffuse transmitter and a phong mat, as described here (scroll down for the mat settings used there).
Users browsing this forum: Majestic-12 [Bot] and 3 guests
