.exr maps
- Kosmokrator
wow nice colors nice bug...
ok i dont have any idea why this happents...
u can post your exr map here?what emmits exactlly?
Good question - make sure you're set to latlong.spherical or latlong?
Example:
<env_map>
<latlong>
<path>example.exr</path>
<gain>1</gain>
</latlong>
</env_map>
- afecelis
@Jacco: what 3d modeling app are you using?
There was some insight on this regard for blender. Check it here:
http://www.indigorenderer.com/forum/viewtopic.php?t=518
since I posted this under the blender exporter forum I assume i'm using blender
thanks for the link. it is working now. I can see the refection of the map on my car. allthough the background (world) of my picture is still grey.
Jacco;
Jacco;
- afecelis
you're absolutely right! I got confused with another thread But I'm glad it's working now. I recommend you to try converting some of those evermotion hdrs into exr. They give some nice resultsJacco wrote:since I posted this under the blender exporter forum I assume i'm using blender
Jacco;
Play with the gain setting (turn it way up - try 1, 1000, 100000, etc). Do you have any emitters? There's been a lot of confusion about how environment maps interact with other light sources. Here's the best response on the subject I've read:
http://www.indigorenderer.com/forum/viewtopic.php?t=84
Even if that isn't the problem, it's something everyone should be aware of.
EDIT - Forget this, I'm wrong!
In the XML file, is there a background bit that has the EXR in, and one with something like
If so, delete the one with the RGB bit in. No idea if this is the problem, but possible
Ian
<spectrum>
<rbg> 1 1 1 </rbg>
</spectrum>
Ian
Users browsing this forum: No registered users and 84 guests
