trouble in indigo land.
I have trouble getting indigo working with .nk materials. And how the heck do you get the .igm materials working. Cause i can't get it to work. I am running 64 bit linux with indigo 1.0.1
first, get Indigo 1.0.5.2
Also check, if there is a newer blendigo... (the newest is written for 1.0.4, so it doesn't support the very newest features)
What's so hard on getting the nks to work?
Simply make your materials a phong and in the nk-textfield, write "yourNK.nk".
The .nk is important. Wont work without that
For igm, you need to set your material to "external" and then search for the material
Be careful that your igm only includes a single material...
Well Kram. I can't get the Indigo 1.0.5.2. (So many numbers.) 'Cause I am running Ubuntu linux 64 bit. And Wine or other windoze emulators don't work on my system. So I have to stick with the latest build for my system. Unless Ono makes a new Linux 64 bit version really soon.
I have used .nk materials in earlier works. But that was also earlier Indigo versions. I made a phong material and wrote au.nk. But when i opened Indigo in the terminal it states that it can't open the nk. materials. So I tried ag.nk. And the same thing happened.
And that igm material. I did as you said, even before you said it Kram, but the same error came up. I downloaded the fabulous .igm material for the orange juice in simple renderings thread and there was, look and behold, and error displaying that the material couldn't be opened. Under the building of the ktree or whatever it is in the start of the indigo renderer. it says it has loaded the igm successfully. But that ain't right, cause that window shuts down after just a few questions.
Ok...
That's strange...
Nothing changed with nk and the juice doesn't have any new stuff, which wasn't included in 1.1 I'm quite sure.
This means, blendigo can't be the problem... VERY strange.
(Why can you use Indigo 1.0.1, then? I thought, there was no 64bit build? Did I miss something? O.o)
What do those messages say, exactly? Any tag that can't be read?
Also (re)check your nk data folder... And try to redownload Indigo and replace the nk folder with yours... Maybe, there was a problem...
That's strange...
Take a look here my dear Kram.
http://www.indigorenderer.com/joomla/in ... e&dir=DESC
Down the page there is a linux 64 bit version. There seems like 1.0.1 came out as 32 bit windoze and 64 bit linux build only.
And here is what it tells me:
Fatal Error: SceneLoaderExcep: MaterialExcep: ComplexIORExcep: ComplexIORDataSetExcep: Failed to open file 'nkdata/ag.nk' for reading. (In element 'phong', around line 118, column 9)
