MtI 0.9
phr0stByte:
I was kinda incorrect about the .obj n-gon thing. I had another look at your fan blade and found that it wasn't the n-gons causeing problems, it was the fact that the surface was not closed.
I found this when I deleted the large faces, and tried to re-make them, the object only half filled, broken where the outside loop wass broken.
I fixed the outside loop, remade the large faces, and it renders OK.
see attached.
see attached.
- fanblades-OBJS.zip
- The objects in .obj format in case you can't read the Maya file
- (91.7 KiB) Downloaded 237 times
- quick render with sunlight, doesn't really show the glass too well, but I'm sure you can do abetter job ;)
- untitled.igs.png (580.93 KiB) Viewed 4465 times
- fanBlade.zip
- Maya 2008 project in .ma format. If you want to load this in v8.5, open it in a text editor and replace the versio strings near the start with 8.5 instead of 2008 ;)
- (116.44 KiB) Downloaded 263 times
- Phr0stByte
- Phr0stByte
- Phr0stByte
dougal2
Cool - I will check it out!
[EDIT] Hey, I still have never gotten the icons the the script to show - even in Windows. mel script output gives me:
rudimentaryHelp_mti
// Warning: File not found: mti_CamRed.bmp //
// Warning: File not found: mti_SunRed.bmp //
// Warning: File not found: mti_IES.bmp //
// Warning: File not found: mti_ExitPortal.bmp //
// Warning: File not found: mti_makeInst.bmp //
// Warning: File not found: mti_Polygonize.bmp //
// Warning: File not found: mti_reverseNormals.bmp //
// Warning: File not found: mti_delHistory.bmp //
// Warning: File not found: mti_AddCustomAttrib.bmp //
// Warning: File not found: mti_Sharp.bmp //
// Warning: File not found: mti_Smooth.bmp //
// Warning: File not found: mti_toggleFaceNormals.bmp //
// Warning: File not found: mti_toggleBackfaces.bmp //
// Warning: File not found: mti_Triangulate.bmp //
// Warning: File not found: mti_ToggleUndo.bmp //
// Warning: File not found: mti_FlushUndo.bmp //
Not a huge problem - just a minor annoyance. Any thoughts?
rudimentaryHelp_mti
Hi guys ! Happy new year !
Unfortunately I'm just here to grab the last revs, this computer I'm using is not mine etc... the prob is that without svn rep installed there is absolutely no way to get the last rev so I'm really pissed off, been trying for 30mn to get rev 195
on the svn server ther is no invite to get the files etc, how do I ? Where can I log in (I do remember my login data) ?
Thx and sorry if I'm a bit oppressed, dunno when I'll be able to connect again that's why I'm totally unhappy
Anyway glad to see you around, keep it up ! I'll be back !!!
SVN checkout is anonymous CTZn...
also, see attached
svn co https://svn.hamsterfight.co.uk/svn-mti/trunk
- MayaToIndigo-r195.zip
- (47.38 KiB) Downloaded 224 times
- Phr0stByte
phr0sybtye:
Indigo supports polygonal meshes only.
The subdivs exported from blender are still meshes.
With MtI we are tied to using the OBJExport plugin to do the mesh work for us, we can only export objects that are supported by the plugin, = meshes.
I seem to recall proxy subdivs are exported OK - can't remember though, I've been out of 3D land for a few weeks trying to get some real work done
re: broken images in your Maya setup, try adding
to yout Maya.env file.
Also make sure you actually have the icons installed in
/home/user/maya/2008-x64/prefs/icons
XBMLANGPATH = /home/path/to/where/the/icons/are/
Thank youdougal2 wrote:SVN checkout is anonymous CTZn...also, see attachedCode: Select all
My point is that from now the computers I'm using have not svn installed; but anyway I'll stick with public updates.
cheers !!!
