Indigo or Blendigo Bug?
Well ... im trying make a scene with env. map + emitter, but when a do render with emitter the env. map do dark ... buuuut when i turn emitter off he work ... look the examples and sry about my english
Emiiter ON + Env. MAP
Emitter OFF + Env. MAP
btw...its the second time with same problem
thx
I use, Indigo_v09_test06 + Blendigo 9 s2
thx
that's 'cause you use reinhard tonemapping... (reinhard auto exposures your pic as good as possible, it tries to avoid pure black and pure white pixels)
two ways to get arround that:
1) make your emitter weaker (don't turn it completely off, but make it weaker)
2) use linear tonemapping - a bit harder to use than reinhard, but as long as you export the igi and you can post edit the tonemapping in violet, you shouldn't have troubles with that
- deltaepsylon
I guess its better with only emitters. BUT (and its a big but) only if you add some other low power emitters (perhaps 2) around the model, i mean like long rectangular boxes so that you dont get 2 funky shadows. that way, the scene will still be bright, but you will still see the headlamp thing.
-OR-
you could go for a nice smokey.foggy effect and put the whole thing in a giant SSS cube and see the headlamp from the model illuminate a cone of light, that'd be pretty kewl
mind uploading the blend file? id like to take a closer look at that thing, looks interesting
-OR-
Blend file uploaded
Need only finish the armature and textures...annnnnnnddd im not very good about modeling but somenthings work
http://www.inovaplacas.com.br/besteiras/projeto.rar
ftp fron my enterprise
- deltaepsylon
Users browsing this forum: DotBot [Bot] and 90 guests
