Question about edge artifacts and some test results
CoolColJ
Post by CoolColJ » Mon Jun 25, 2007 9:51 pm
See the attached pic - note the edges of the box - will these artifacts go away with more rendering time? If not what's up with the artifacts?
So far rendered in 30mins on my P4 Northwood 3.14ghtz machine. Models imported with Cindigo from C4D R10. Scene is lit by Indigo sky and sun directly above the box. Box is basicly a cube with one side cut out, exported model with no normal smoothing. All diffuse materials
settings
"metropolis" "true"
"large_mutation_prob" "0.4"
"max_change" "0.03"
"max_num_consec_rejections" "500"
"max_depth" "1000"
"bidirectional" "false"
"hybrid" "true"
30min render of models exported from C4D with cindigo
CoolColJ
Post by CoolColJ » Mon Jun 25, 2007 10:04 pm
also some results of a test I've been experimenting with some parameters with this scene and a few others
I found that max_change of 0.03 to 0.02 to be better than the default of 0.01 - resolves the noise quicker and with more detail
large_mutation_prob with low values of like 0.01 to 0.001 slows down the render, but the scene resolves quicker!
bidrectional mode really slows things down.... but sometimes clears up the noise in interior scenes quicker :?:
anyway some tests of the above scene - all rendered in 3.5 mins
in order of fastest - lowest noise etc - even the jpeg sizes agree with this order! More noise = bigger jpeg size :lol:
"metropolis" "true"
"large_mutation_prob" "0.01"
"max_change" "0.03"
"max_depth" "1000"
"hybrid" "true"
"metropolis" "true"
"max_change" "0.03"
"max_depth" "1000"
"hybrid" "true"
"metropolis" "true"
"max_change" "0.03"
"max_depth" "1000"
"bidirectional" "true"
"hybrid" "true"
"metropolis" "true"
"max_change" "0.03"
"max_depth" "1000"
"hybrid" "true"
okazaky
Post by okazaky » Mon Jun 25, 2007 10:11 pm
Yep, I know that issue.
I think it's a MLT problem because I don't get such artifacts by using PT/BDIR PT.
Moreover I think that the MLT modes are not as accuarate and fast as the PT modes. But it's only a thought ;)
CoolColJ
Post by CoolColJ » Mon Jun 25, 2007 10:52 pm
well I did a 30min render in Path tracing mode only and same thing.....
it did reach higher sample count numbers so does seem to be faster in this scene :o
attached
okazaky
Post by okazaky » Mon Jun 25, 2007 10:56 pm
Hm, are the walls made of one mesh or is every wall a single geometry?
CoolColJ
Post by CoolColJ » Mon Jun 25, 2007 10:56 pm
although I have a feeling Bi-directional mode may fix this as the above test renders with BD mode don't seem to have this artifact
stay tuned - rendering now.... with BD and in path tracing mode
CoolColJ
Post by CoolColJ » Mon Jun 25, 2007 10:57 pm
okazaky wrote:Hm, are the walls made of one mesh or is every wall a single geometry?
one mesh as far as I know, used the Cindigo object export tag
SimonLarsen
Post by SimonLarsen » Mon Jun 25, 2007 11:10 pm
You should check it.
I think it is light coming in from the cracks between the walls.
Post by CTZn » Mon Jun 25, 2007 11:22 pm
What's the color of the box ? If it's too white, light bounces are strong.
CoolColJ
Post by CoolColJ » Mon Jun 25, 2007 11:36 pm
it's just a grey box
anyway it doesn't show when bi-directional mode is turned on! :shock:
in either path tracing, MLT or MLT-Hybrid. But its ure slows the render down
just a 15min render to test in Path traced Bi-directional mode
so is this a glitch, a bug or something else? :)
CoolColJ
Post by CoolColJ » Mon Jun 25, 2007 11:47 pm
now with MLT hybrid bidirectional - no artifacts as well, but man this took longer! Needed 20mins for the same sample level as above
Post by OnoSendai » Mon Jun 25, 2007 11:54 pm
I think it's an artifact due to ray origin nudging, the current nudge distance is 0.1 mm, so If your scene is too small, you may see artifacts around the edge of the box. You can fix the artifact by enlarging the scene, or making the walls double-sided, i.e. solid objects.
CoolColJ
Post by CoolColJ » Tue Jun 26, 2007 12:30 am
OnoSendai wrote:I think it's an artifact due to ray origin nudging, the current nudge distance is 0.1 mm, so If your scene is too small, you may see artifacts around the edge of the box. You can fix the artifact by enlarging the scene, or making the walls double-sided, i.e. solid objects.
Well the Cinidigo export scaling parameter is set to 0.01 by default
I've been using a 0.1 value, and it seems this is too small then
when I use a scaling of 1.0 - no more artifacts in render :)
8 min render in MLT Hybrid mode (no bi-directional) - much faster rendering for the same sample level as the above 2, but seems noisier than the 2nd render though
deltaepsylon
Post by deltaepsylon » Tue Jun 26, 2007 1:25 am
I say use blender! :lol: JK, use whatever you feel most comfortable with
CoolColJ
Post by CoolColJ » Tue Jun 26, 2007 1:31 am
deltaepsylon wrote:I say use blender! :lol: JK, use whatever you feel most comfortable with
I have blender here as well, but it's completely Alien to me!! :?
C4D is so much easier to use. I wish I could get the 4 view mode of C4D in blender, and file open dialog in blender is aggravating
I admit blender exporter is probbaly better developed right now...
