Specular material help
okazaky
Post by okazaky » Fri Jun 22, 2007 6:36 am
I've got a little problem regarding specular materials. I want to create a material like this one: http://elqx.com/indmatdb/inc/imgs/image ... .jpg&s=220
In the attached testscene (R 9.6 file format) are three tests but I don't get such a material.
Can anybody help me?
Best regards,
okazaky
testscene.zip
(98.19 KiB) Downloaded 311 times
Post by Kram1032 » Fri Jun 22, 2007 7:04 am
Post by fused » Fri Jun 22, 2007 8:32 am
if you still dont get similar results as arnes mats check your scale.
your objects may be way too small
okazaky
Post by okazaky » Fri Jun 22, 2007 9:24 pm
Thanks for the quick help. I will try to play around with the scale later :)
EDIT:
Thanks again, works very well with kilometers instead of centimeters in the units setup!
Post by Kram1032 » Sat Jun 23, 2007 4:40 am
xD KILOMETERS? that's quite much...
okazaky
Post by okazaky » Sat Jun 23, 2007 4:45 am
Yep, but meters unfortunately also don't work for me :(
Post by Kram1032 » Sat Jun 23, 2007 4:46 am
strang xD
how can that be?
okazaky
Post by okazaky » Sat Jun 23, 2007 4:57 am
Here's another test with a specular material.
Units: kilometers
sphere 1 size: 73.425 km
sphere 2 size: 124.785 km
sphere 3 size: 198.348 km
every sphere uses the same material.
The bigger the spheres get, the less transparent and the more colorful they get. Is this a bug or am I totally wrong in the way of setting up the scene?
regards,
okazaky
Post by Kram1032 » Sat Jun 23, 2007 5:09 am
no, that's simply the problem, you have - it's the point, why you don't get a visible colour with cm or m...
Absorbtion is the (amount of light, absorbet per meters)^-1 (= meters, where an amount of light is absorbed)
and you set it extremely low - can't even be absorbtion 1 xD
that would look less transparent, in so many kilometers.
It's simply realism ;)
Example: If you have about 1l Milk, in a bottle, can you see through it?
But if you have that l on a big milk-varnish - can you see through it, then?
Ok, not the BEST excample, as Milk also has SSS... but it should show you the point, anyway. ;)
okazaky
Post by okazaky » Sat Jun 23, 2007 5:23 am
That sounds very logical :wink:
But in reality there are also very small objects that can be very intransparent (for example some kind of marbles)
There is not a way do create something like this at the moment?
regards,
okazaky
Post by Kram1032 » Sat Jun 23, 2007 5:26 am
yes, I know....
actually, ANY object has SSS... so, even a brick has light trespassing.
But it's your settings, that must be completely wrong ;)
I guess, the absorbtion is in 0-1 range + a multiplier...
which Prog which Exporter?
Blendigo has a "Gain" Value, next to several things. It EVER is a simple Multiplier ;)
okazaky
Post by okazaky » Sat Jun 23, 2007 5:30 am
I'm using Cinema 4D & Cindigo. Here's a screenshot from the material settings tab ;)
Post by Kram1032 » Sat Jun 23, 2007 7:08 am
I see...
obviously, it needs a gain-value, or anything like that.
I wonder, how it was done, by now... as it shouldn't be too hard to request that.
Maybe, you have to also use uniformal Absorption Coefficient? That may act as a multiplier, if it's unused.... -> values like "0" wont give any absorbtion at all ;)
okazaky
Post by okazaky » Sat Jun 23, 2007 7:56 am
Hmm, doesn't make any difference. I tested a value of 5, 100 and 15000. The render always looks like the one I posted before :(
Post by fused » Sat Jun 23, 2007 8:13 am
strange...
