Cindigo 0.8 - beta 2
CINDIGO 0.8 - BETA 2
newest version is Cindigo 0.8 - Beta 2
read before download
download exporter:
PC Version
Mac Version
edit: stuff
download exporter:
PC Version
Mac Version
edit: stuff
Hmm... blend-material seems to be broke for me. I deleted the old blend-tags which were used with older cindigo. Then I created a new cinema material, then a Null-Objekt and then I gave the Null-Objekt a Material-Helper Tag. In the Helper Tag I selected Blend-Material and assigned two materials in the boxes. The Material is named "blend".
Then I assigned the material "blend" to 3 Objects in my scene. But when exporting the scene indigo crashes with the message "Object blabla tried to use material blend which is not defined".
Do I have to do it another way?
edit:
same with diffuse material. So I guess it's an issue of the new material tag? materials created with the old exporter are working fine!
But the way of reorganzing the GUI etc. is very cool!
edit:
uhm.... for me it works...
you have to create a material helper for the blended materials, too
edit: works with diffuse, too.
do you use R10?
do you use R10?
Re: Cindigo 0.8 - beta 2
YES great fused! definatly a big step forward!fused wrote:hope you like my changes
littlebugfix
download exporter:
PC Version
Mac Version
(or below)
The file contains PC versions for R10 and R9. (R10 users will have to rename the "cindigo0.8.2.cdl_R10" to "cindigo0.8.2.cdl")
edit: compiled a mac version today!
new in 0.8 - beta 2:
* render settings tag will ask you once to choose an indigo dir (will need that later, no use of that at the moment)
* blend mat is a regular mat type not an extra tag
* mainly GUI changes
* and lots of code reorganization
fixed-list 0.8 - beta 2:
* blend mat bugs
* exporting igs contents multiple times
* you can now use material names with dots (e.g. "mat.1")
known bugs/issues 0.8 - beta 2:
* only UVW-mapping supported
* normalization of Vertex Normals is disabled(doesnt work properly), indigo will do that for now (and it takes very very long)
* there have been lots of changes to the material tag, it might not be compatible with materials created with older versions of cindigo
please post bugs
a good tutorial can be found here (only german and italian, hope someone will translate it to english soon).
edit: attached Mac version (only R10)
download exporter:
PC Version
Mac Version
(or below)
* blend mat bugs
please post bugs
- Cindigo 0.8.2.zip
- Cindigo 0.8 - beta 2
!Mac Version! - (101.26 KiB) Downloaded 766 times
- Cindigo 0.8.2.zip
!PC Version! - (263.71 KiB) Downloaded 6194 times
Why bother about an exporter for MacOS anyway when there is no Indigo for the Mac-users available ?! I was kind of stumped when I was asked on the German forum why there is an exporter if there is no native MacOS-Indigo.fused wrote:
im curious to see wich version gets more dl's... mac vs pc (competition, as always)
Very valid question :\
Michael
@micha: no, i dont think so. i work on a mac and have bootcamp installed, i also use parallels for preview renderings.
and there seem to be pretty many c4d users working on mac.
mac version: 16 dl's
pc version: 27 dl's
more than half of the Cindigo 0.8 beta 2 users are mac users
and.... pls spread the news to all other forums you know (would do it myself but im lazy)
edit: oh ich seh grad, dass du das schon hast... danke
pc version: 27 dl's
Users browsing this forum: Majestic-12 [Bot] and 22 guests
