Making a 3D (viewport-ish)/real-time renderer.. from skratch
Okay, lemme start from the top:
I didn't comment my code with what each code offset does, unfortunately - but this should help you.
fileSize=(width * height * 3) + 54
'this is the file size in bytes, for our 24-bit dib
bitmapDataSize=(width * height * 3)
'this is the actual bitmap data size in bytes
Here's the header (you can probably figure it out, but each chr() returns a byte, and &h makes the data passed to it hexidecimal):
chr(&h42) + chr(&h4D) + *4 bytes here for fileSize* + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h36) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h28) + chr(&h00) + chr(&h00) + chr(&h00) + *4 bytes here for image width in pixels* + *4 bytes here for image height in pixels* + chr(&h01) + chr(&h00) + chr(&h18) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + *4 bytes here for bitmapDataSize* + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + chr(&h00) + *image data goes here, scanlines in reverse order. 1 byte R, 1 byte G, 1 byte B. padded to DWORD boundaries if your width isn't divisible by 4*
To create a simple 24-bit bitmap, with no wierd settings, that will do.
I remember parts of the header, specifying for example the offset to the beginning of the image data, but that's not important for this exercise - i built it into the header code.
If this doesn't make sense, tell me.
You know how to do simple file IO in C++?
Create a handle to a new file.
Next, we prepare the header data for your bmp file.
The header is going to be 54 bytes long, for a standard 24-bit uncompressed bmp file.
Write the following to the new file you just created:
With me so far? That takes care of the header of the file.
To finish, simply write, line by line, the contents of the generated framebuffer, into the file next. Remember to write the lines in reverse order, or the image will be upside down when viewed elsewhere.
Possible example:
Is that more clear?
424D
000000003600000028000000
0100180000000000
00000000000000000000000000000000
Possible example:
for (int i=0, i < imageHeight, i++)
for (int j=0, j < imageWidth, j++)
'pseudo-code - i obviously don't know what your functions look like
bmpWriter.AddPixel(framebuffer.getValue(i, j));
I am probably to new to C++ to understand this
I am trying, but I can't make sense this bmp stuff
All of this, except the loop parts is something I just copyed and pasted..
It does save a .bmp file with all the info, but not the image, obviously
Does not work.. I have just been using arrays for x/y info storing, is that okay?
pixel[x][y] and img[x][y][(r,g,b)]
Arg...
EDIT:
Hand drawn replica of one of my results:
FILE *f;
int filesize = 54 + 3*WIDTH*HEIGHT;
unsigned char bmpfileheader[14] = {'B','M', 0,0,0,0, 0,0, 0,0, 54,0,0,0};
unsigned char bmpinfoheader[40] = {40,0,0,0, 0,0,0,0, 0,0,0,0, 1,0, 24,0};
bmpfileheader[ 2] = (unsigned char)(filesize );
bmpfileheader[ 3] = (unsigned char)(filesize>> 8);
bmpfileheader[ 4] = (unsigned char)(filesize>>16);
bmpfileheader[ 5] = (unsigned char)(filesize>>24);
bmpinfoheader[ 4] = (unsigned char)( WIDTH );
bmpinfoheader[ 5] = (unsigned char)( WIDTH>> 8);
bmpinfoheader[ 6] = (unsigned char)( WIDTH>>16);
bmpinfoheader[ 7] = (unsigned char)( WIDTH>>24);
bmpinfoheader[ 8] = (unsigned char)( HEIGHT );
bmpinfoheader[ 9] = (unsigned char)( HEIGHT>> 8);
bmpinfoheader[10] = (unsigned char)( HEIGHT>>16);
bmpinfoheader[11] = (unsigned char)( HEIGHT>>24);
f = fopen("C:/ti_img01.bmp","wb");
fwrite(bmpfileheader,1,14,f);
fwrite(bmpinfoheader,1,40,f);
//Set pixels
for(int y = 0; y < HEIGHT; y++){
for(int x = 0; x < WIDTH; x++){
if(pixel[x][y] == '1'){
printf("#");
}else{
printf("·");
//WHAT THE FUCK!!!???
printf("\n");
fclose(f);
Arg...
EDIT:
Nice antialiasing!
Well, your frustrations at least convey to me your skill level in C++
I don't have time for indepth fix, but here:
Now try. You weren't actually writing the results into your image file
Note that your intended image will be upside down, and paint.exe (which is the program I used to test my output ) might display it oddly if your width isn't divisible by 4. The .bmp spec specifies that image data be padded to DWORD boundaries.
I'm actually quite surprised, arne - I assumed you were a much more experienced coder than I
FILE *f;
//Set pixels
//printf("#");
//00FF00 is RGB(0, 255, 0) - draw a Green pixel basically
fwrite(0x00FF00, 1, 3, f);
}else{
printf("·");
//printf("\n");
fclose(f);
Nice work, Arne. Great to see the progress
Thanks, Dave
I made a simple "rotate animation" with it
AVI | MP4
It took like 0.5 sec to generate and save 35 images
I have some bad normal issues
I will fix the, hehe.
Also, what exactly does this "error" mean?
It's seems to be an error Cygwin print beacuse I have to many variables or something
This limits me to 320x240 images, and not very big models...
AVI | MP4
10 [main] a 2104 _cygtls::handle_exceptions: Error while dumping state (probably corrupted stack)
Segmentation fault (core dumped)
I've never used cygwin. You get the error when you try to write an image over a certain size?
Why are you using cygwin - IIRC its a *nix layer for windows, right? if your program is just using stdio.h you don't need it.
Or are you more familiar with *nix programming and are using it because of that?
Users browsing this forum: No registered users and 106 guests
