MayatoIndigo Developement
SuperDupont?
I think it is safe to say that the development of MayaToIndigo is open, any
contributor is welcome. Hence a minimal structure is required, and that's
what this thread is supposed to be: a topic to discuss about orientations and
organizing development.
blank
blank
I just don't know how that works but that'll come in time...
Few things we should discuss:
- The name: I like Mayingo, what do you think ?
- closed source code (like IME): I don't wan't to include anymore that kind of stuff into the project, now we're stuck with IME wich was a great addition in the past but now we can't make it evoluate; I suggest we left it appart (soon if not yet). Anyone can make a closed source exporter but it's likely he will work alone. I know yourdaftpunk made a v2 but he forget about us. Crap.
- well, what else ? Er... I'd like to have something like a "code tree", in order to expose and share the structure of the project. Would SVN allow this ?
Concerning the name: I like Maya2Indigo or MayaToIndigo, or even mio...
Concerning closed-source exporters:
we could link the IME-Checkbox to a mti_UseExternalExporter script, call
whatever that script says and just get a string as a feedback, if somebody really feels the need to toy with something like that...
Concerning SVN: How complicated is it to use? And can we break the whole thing into small parts that interakt which each other, so when someone wants to improve a module, he just modifies that one.
I've made a small update to illustrate this principle (calling mti_MakeCameras.mel with some parameters to generate the camera data...)
(and integrated:
- a Locator-based approach to instancing, using a custom prefix attribute in the locators transform
- started with a simple script to sweep in predef shaders (custom attribute has to be assigned to a phong shader, feel extrrremely welcome to add your fav. shaders
- added an efficacy statement that interpretes the grey-value (color) of an emitter-shader as multiplicator (*100) to determine the wattage of the light.
regards !
[ Lets really prepare a simplified version of this script with a rudimentary tutorial explanation, and oui!, let's start recruiting once 0.7.6 of Indigo is released.]
(and integrated:
regards !
- Update.zip
- (22.55 KiB) Downloaded 398 times
Whatever you want my point was to avoid confusion with M2I (Max to Indigo). Like "blendigo", mayingo can not lead to confusion; but I don't care, it's just a nameConcerning the name: I like Maya2Indigo or MayaToIndigo, or even mio...
I know nothing about SVN, just that it is supposed to help with differents versions. As usual, Wikipedia can give an insight. Otherwise, a modular system is the best choice like you said.Concerning SVN:
If you mean commenting out the scripts and preparing them for modularity, let's rock it !Lets really prepare a simplified version of this script with a rudimentary tutorial explanation
May I watch you do ? you're so productive
Oh, I thought today that every developer could have it's own thread to post updates but SVN will save our mind I hope !
And for now I think that all that someone playing with the scripts has to do is to maintain a list of changes. Say the last version arneoog posted is the reference.
More Proposals:
IndigoOnMaya
MayaGo
MayaToIndigo
Besides, it would be great if arneoog could integrate one version
of MayaToIndigo once he's done with the materiallib, as the official starting-point. (Beginning next Weekend, isn't it?)
[ I'll post one update till then, fixing some bugs and clearing the interface somewhat...]
[And now to something completely different:]
Q 1: How do you get Indigo to start from the MayaUI?
Q 2: What is the rational behind the luminance/ gain settings for daylights?
I found the default settings not working.
IndigoOnMaya
MayaGo
MayaToIndigo
Hehe
Maye I can do it next weekend
I'll then collect all MTI 0.7.xx updates into one, as the starting point
Q 1-A: This is something I've been trying to do for ages...
But I can't get it to understand that indigo.exe must be ran inside of it's directory...
Maybe find the mel script Maya uses to open FCheck...
Q 2-A: Ah, yes... That was a 0.7.3 indigo hack It should be removed..
PS: MayaToIndigo is still my favorite name
MayaToIndigo !
That could be the name we use for our project!
About Q1
Arne, I toyed with starting indigo from commandline, and it seems to kind of works:
try
$xmlFile = "1.xml"; // requires 1.xml in indigo-homedir
$threads = 1;
string $cmd_string = " cmd /k " + "cd \"d:\\program files\\indigo_07_test5\" && d: && dir && indigo.exe " + $xmlFile + " -t " + $threads + " && pause";
print ("CHECK\ncommand string: " +$cmd_string +"\n\n");
system ("start" + $cmd_string);
System is still complaining about inifile, but starts to render nonetheless.
(to read a nice piece of garbage, either check my addons to mtiGen or refer to cmd /?, I don't know what I like more. hehehehe.)
About Q2
There seems to be a power-drawn statement that is pretty cool and that has something like <overall luminous efficacy> that accompagnies it.
Anybody know what it does, and what should be our default for it?
I found out that with a gain of 1.0, you have to set <overall_luminous_efficacy> only to 1000000000000 to be well visible in sunlight. ???
</spectrum>
<efficacy_scale>
<power_drawn>50</power_drawn>
<overall_luminous_efficacy> 20 </overall_luminous_efficacy>
</efficacy_scale>
Q3:
If the <include> statement works as someone pointed kindly out,
we may have a problem hooking Alias-Shadernames up with static mti-Library-files. How do we cope with this?
One stomach turning method would be to rename all the shaders to correspond to the <material>statements of the lib on the fly while exporting, and changing them back later on.
I don't like that really much, what do you guys think (and gals out there, by the way, or do they know a better way to spend there time )
Q4:
Concerning F-Scale:
Is F-scale in any way influencing rendering speed (similar to a real camera)
I guess not, and then 50 is a pretty reasonable default, otherwise, let's check it...
About Q1
try
$threads = 1;
About Q2
</spectrum>
<efficacy_scale>
</efficacy_scale>
Q3:
Q4:
Concerning F-Scale:
