0.6 test 2... half baked or fully baked? :)
You are very welcome! btw. it would be superb if we could specify
the path for the tree_cache in a later release so that it will be not
to confusing. For example if I have 2 scenes I like and would like
to play with it longer, on the other hand I have 10 testscenes ...
I dunno which tree file I can delete or not. If I could use the CLI
to give indigo another path for the cache for those files I wanna
keep this would be helpful. ;o))
But this is just something for a later release, don't hurry, just keep
it in mind. Thanx!
take care
psor
it in mind. Thanx!
take care
psor
Cool
I did this test to compare speed (30 min)
It's less noise in the 0.6 test2.
I notised some normal smoothing problems have been fixed but now a new one have emerged...
The object inside looks like it has normal smoothing OFF, but it's exactly the same scene with normal smoothing ON!
Well well, it's not a complete version
inifile.txt
Hey Nick,
Nice you put the cache_trees in!
Testing different Materials & setting on scenes now gets even faster
I got 2 Questions about the v0.62 inifile.txt
1) You reduzed the "max_num_consec_rejections" down to 100 from 1000 in 0.61.
What this is about? I even don't have a clue about this option ^^
2.) The "russian_roulette_live_prob" is tagged out using -- , why?
Thank you for the great work, I'll start some testscenes soon
Re: inifile.txt
I would like to try to answer your questions.
get rid of white dots caused by caustics. Thats the pro ... the contra
is it is not unbiased anymore ... but you have the choice ... nice! ^^
Old example:
Indigo v0.5 Test3 (hardcoded max_num_consec_rejections = 1000)
-------------------------------------------- Click image to enlarge ---------------------------------------------------
resized to 1360x1020 (original image)
rendertime: 100h
box: AMD64 3000+ @2,3GHz; 2GB ram
Indigo v0.5 Test5 (max_num_consec_rejections = 100)
rendertime: 100h
take care
psor
This option will introduce more biased calculations which will help toZom-B wrote:1) You reduzed the "max_num_consec_rejections" down to 100 from 1000 in 0.61.
Old example:
rendertime: 100h
rendertime: 100h
This option is not needed for bidirectional MLT ...Zom-B wrote: 2.) The "russian_roulette_live_prob" is tagged out using -- , why?
take care
psor
