tilt/shift camera
Tyler
tilt/shift camera
Post by Tyler » Fri Nov 23, 2018 2:19 am
hi everybody,
is there a way to tilt/shift the lens of a camera in c4d/indigo?
thanks
s.
pavoda
Re: tilt/shift camera
Post by pavoda » Fri Nov 23, 2018 4:06 am
Hi, try in C4D - camera - object - film offset x, y. In indigo - camera - shift up, right...
Tyler
Post by Tyler » Fri Nov 23, 2018 4:28 am
Hi pavoda,
thanks, i'm gonna try but i assume it only shifts the frame of the camera, there's no tilt (different angle of the lens and the sensor)?
Post by Oscar J » Fri Nov 23, 2018 5:06 am
As you say, I'm pretty sure Indigo only features a shift lens, but not tilt. The former has a lot of arch viz applications, while I've never actually seen the latter being used in a 3D rendering context.
Post by pixie » Fri Nov 23, 2018 5:20 am
I always thought of tilt/shift as being the same. What Cinema calls "film offset", indigo calls shift up/right and theplugin takes care automatically.
Post by Oscar J » Fri Nov 23, 2018 5:36 am
Aye. But you can't get "fake" DOF to generate miniature shots like you can with a tilt lens. Fortunately the effect is somewhat easy to replicate in Photoshop using lens blur and a vertical gradient as depth map.
Tyler
Post by Tyler » Fri Nov 23, 2018 5:44 am
when you tilt the camera you can change the perspective effect (for architecture for example to have the buildings "straights" but the shift effect is much more interesting (to me) cause you can affect the depth of field. But ok, i'm gonna try what is possible, thank you all for your answers/help.
Tyler
Post by Tyler » Fri Nov 23, 2018 5:47 am
yes Oscar, thank you, that is what i'm gonna do, but i always prefer have a nice raw render image on which i do the less post process, always seems much more natural to me, a little like if you work in a real environment with a camera.
Post by pixie » Fri Nov 23, 2018 6:56 am
Perhaps changing the scale of the scene and narrowing the fov might cut it... after all in real life these lens makes the scene feels small you might as well make the scene smaller.
Tyler
Post by Tyler » Fri Nov 23, 2018 8:44 am
yeah pixie but that is not about controlling the power of the dof but basically when you shot, you aim to something and what is closer and further of that focus point you aim at is affected by the dof perpendiculary to the lens, with a tilt shift you can control the rotation of that perpendicular line of focus.
some examples:
http://www.tiltshiftphotography.net/til ... -examples/
Tyler
Post by Tyler » Fri Nov 23, 2018 8:49 am
pavoda
Post by pavoda » Fri Nov 23, 2018 9:11 am
you may get this effect when you resize 3D model to very small :)
Tyler
Post by Tyler » Fri Nov 23, 2018 9:23 am
ok, i'm gonna try then, thank you ;)
burnin
Post by burnin » Mon Nov 26, 2018 3:28 am
Or simply mimic, recreate reality :D It's Indigo!
Jeremy Cox: Down the Rabbit Hole: Adventures in Cinema 4D
> Starts @ 20min
Tyler
Post by Tyler » Mon Nov 26, 2018 4:02 am
> Starts @ 20min
WOOOOW ;) so so cool!
Users browsing this forum: Semrush [Bot] and 1 guest
