[REQ] Indigo instance color variation shader
Re: [REQ] Indigo instance color variation shader
Post by pixie » Sun Mar 08, 2015 2:17 am
Amazing things things happens to whose who wait! xD
zeitmeister wrote:Got it! :D
First three images ONLY ONE color texture. There are 8 different trees with 8 different alpha leaf blend materials; all accessing the main color changer material.
So this way I got to change/apply/setup the color variation shader ONE TIME, but get 8 different alpha leaf materials out of it.
Last picture using ONLY TWO textures, but color and gamma variation applied.
def eval(vec3 pos) vec3 :
	let
		NUM_TEXTURES = 2
		tex_index = floorToInt(gridNoise(real(objectId())) * NUM_TEXTURES)
		c = sample2DTextureVec3(tex_index, getTexCoords(0))
		id = real(objectId())
		gamma_var = paramGammaRandomAmount()
		shift_gamma = max(0.0, (1 - gamma_var) + gridNoise(id) * gamma_var * 2.0)
		colour_var = paramColorVariationAmount()
		colour_shift = (vec3(-0.5) + vec3(gridNoise(id), gridNoise(id + 34534), gridNoise(id + 9876465))) * (colour_var * 2.0)
	in
		vec3(pow(c.x, shift_gamma), pow(c.y, shift_gamma), pow(c.z, shift_gamma)) + colour_shift
leaf_color_variation.igm
zeitmeister wrote:Thank you a lot!
The only knickknack is the fact that setting up the shader is not possible in the C4D exporter.
fused may have to invest work here, so that the C4D Indigo shader window offers the same possibilities as the Indigo standalone GUI shader window. Plus working and exporting things correctly.
BTW: Ono, does that shader "flicker" or sample everything new when rendering an animation?
And if yes, how can we interdict that?
Can't you use the 'export' material?
Post by OnoSendai » Sun Mar 08, 2015 3:34 am
zeitmeister wrote: BTW: Ono, does that shader "flicker" or sample everything new when rendering an animation?
The randomness is based on the object id which should stay the same frame to frame, so there shouldn't be flickering. Let me know if there is!
Post by zeitmeister » Sun Mar 08, 2015 4:02 am
OnoSendai wrote: The randomness is based on the object id which should stay the same frame to frame, so there shouldn't be flickering. Let me know if there is!
Very cool, thank you!
Cheers, zeiti
Post by zeitmeister » Sun Mar 08, 2015 4:40 am
pixie wrote:Can't you use the 'export' material?
Of course, but then I can change everything, all textures and parameters, only in Indigo standalone GUI... and that's not what we want.
We want full ISL-shader-access in the exporters.
Post by pixie » Mon Oct 05, 2015 9:05 am
fused wrote:
zeitmeister wrote:Yikes... awesome! :mrgreen:
Then please tell Yves how you did that!
This should be a feature implemented in every available exporter!
I once did color variation in instances for cindigo, but scrapped it :)
can be done, easily :)
Why why why!!!! :x
:mrgreen:
Post by pixie » Thu Nov 03, 2016 10:28 pm
As a mid-gap solution you can now have it as in 'external' type of material.
Post by pixie » Thu Nov 03, 2016 10:30 pm
Sadly this shader doesn't work on GPU. :(
Failed to find function 'l1l1llll1lll11l1111111l111ll1l1ll(FullHitInfo, vec4, vec4)'.
ShaderSpectrumMatParameter user shader code, line 7:
	ll1llll1llllll1l11l1l1l11l111llll = ll1111ll11llll111l1l11111ll1l1l1l((gridNoise(lll1111ll11lll1111ll11l11l1l1ll11(l1
l1llll1lll11l1111111l111ll1l1ll(l111ll1lll11ll1lll1lllllll1l1ll11, l1l111l1l11lllll1111lll11l11l1ll1, l1ll11111l111l1111lllll111l11lll1))) * l1ll11l1ll11l1llll11lllll11l1l1ll))
Post by Zom-B » Thu Nov 03, 2016 10:48 pm
Added to Bugtracker, thanks for the report!
Post by pixie » Sat Dec 23, 2017 2:32 am
It still isn't fixed... :(
Post by pixie » Wed Jul 25, 2018 2:03 am
It seem it is now working
Post by pixie » Wed Jul 25, 2018 2:08 am
Post by zeitmeister » Fri Aug 03, 2018 4:20 pm
Yeah!
Post by pixie » Mon Aug 27, 2018 10:12 pm
Is there a way to get variance in albedo channel as well as in the bump and roughness?
Post by zeitmeister » Sat Sep 01, 2018 8:22 pm
Well we have to change the code into vec2... then it should work in these channels; blend also f.e.
I am too dumb for maths, but I can take a look..
Users browsing this forum: Yandex [Bot] and 0 guests
