A natural situation...
arc en ciel
Re: A natural situation...
Post by arc en ciel » Mon May 22, 2017 3:46 am
yonosoy wrote:A version of "One and Three Chairs". It is "One and Three Wineglass".
Another well-inspired work by Yonosoy. :!:
yonosoy
Post by yonosoy » Thu May 25, 2017 3:49 am
Thank you a lot!
An experiment with custom atmopheres.
"... the hamster don't see the wheel, and this wasn't said before." (yoS eidaN "el Olvidao")
https://www.instagram.com/yonosoy_nada/
Online
Post by OnoSendai » Wed May 31, 2017 3:32 am
Cool stuff, will you enter the competition?
yonosoy
Post by yonosoy » Wed Jun 07, 2017 1:47 am
Thanks Ono.
Experimenting with bubbles inside water.
Seems that caustic process is not reflected in the bubbles walls.
Metropolis bidirectional. Overnight rendering.
yonosoy
Post by yonosoy » Thu Jun 08, 2017 12:12 am
The problem for this scene is the Sun & Sky system (the sun).
With a HDR map lighting the scene.
Bidirectional metropolis + Exit Portal. Indigo´s linear output with color curves correction.
arc en ciel
Post by arc en ciel » Thu Jun 08, 2017 1:29 am
wonderful :!:
did you use realflow for bubble's mesh ?
yonosoy
Post by yonosoy » Wed Jun 28, 2017 11:38 pm
Hi arc in ciel! Thank you.
Simple metaball question in Cinema4d.
Want to play with realflow more over...
This experiment is odd. Oddest in v4.
Capture simulation with eight exit portals.
Volume of gas 100x100x15 meters.
Good to see noise stucture!
disection_of_a_volume.pigs
(4.17 KiB) Downloaded 67 times
yonosoy
Post by yonosoy » Fri Jun 30, 2017 8:39 pm
Hi.
A very simple simulation of the movement of the Troncotron over a surface.
Rendered with GPU in about 5-6 hours.
https://vimeo.com/223739756
yonosoy
Post by yonosoy » Mon Jul 10, 2017 3:15 am
Smoke.
Actually it has an espheric envelope. The volume has 5x5x2 kilometers...
Try to put this in order to share more over.
Originalplan®
Post by Originalplan® » Mon Jul 10, 2017 5:12 am
:shock: That's amazing!
yonosoy
Post by yonosoy » Sun Jul 30, 2017 10:24 pm
Thank you!
But this casual finding don´t fits exactly like smoke in other scales.
Like experiment is amazing...
Clay render.
Focal length, 8 mm.
yonosoy
Post by yonosoy » Fri Sep 08, 2017 6:26 am
Quick and dirty mie_cumulus experiment.
With a LUT in post-pro.
Polinalkrimizei
Post by Polinalkrimizei » Sat Sep 09, 2017 6:43 am
Awesome!!
One of the foggiest renders I've seen! 8)
yonosoy
Post by yonosoy » Sun Sep 10, 2017 1:40 am
Thank you!! Yes, is half a cloud...
Is a bidirectional metropolis with a mie_cumulus volume experiment.
The bands green-violet are there again.
Overnight rendering (12h).
Originalplan®
Post by Originalplan® » Tue Sep 12, 2017 6:14 am
Once again very cool work/concept Yonosoy
Users browsing this forum: Majestic-12 [Bot] and 4 guests
