Hello guys
As the section plan could do some great and interesting stuff
could you add a clipper in mesh mode likes:
https://docs.chaosgroup.com/display/VRA ... RayClipper
Slice/Clipper geometry
Re: Slice/Clipper geometry
Shouldn't such stuff be done inside the 3D app, also for flexibility of texture control?
In C4D this is named Boole, where you can subtract mesh A from Mesh B...
It is not the same "approach".
Boolean equation is a geometry operator in the 3D modeler software.
Slice is more like a clipping plane on an object. (option that you can find in an openGL view)
you can chose if the "hole" should be open or capped.
In 3ds Max Slice is an other operator thatn Boolean, and could be animated.
errare humanum est
