Sroka8888 Rendering Thread
Sroka8888
Re: Sroka8888 Rendering Thread
Post by Sroka8888 » Fri Nov 18, 2016 5:23 am
I go to Cinema4D :D
Substance Painter shader object
Base Color - 2.2
Specular - 2.2
Roughness 1.0
NormalMap OpenGL 2.2
IOR - 0.45
8K Maps
First time put map to FresnelScale IOR map from substance with 0.45 gamma - flat , non contrast but don't have black areas.
GPU
RENDERS
2000x
5-7min with dof sorry :D 3min :D not that resolution
Mateusz Sroka
Platige Image - Lighting / Shading / Look Development Artist, Environment Artist
Post by Oscar J » Fri Nov 18, 2016 5:27 am
Finally some high res renders. :) Cool shading!
Maxime Roz' HDRI's?
Sroka8888
Post by Sroka8888 » Fri Nov 18, 2016 5:37 am
Mateusz Sroka
Sroka8888
Post by Sroka8888 » Fri Nov 18, 2016 6:51 am
Reinhard
Mateusz Sroka
Originalplan®
Post by Originalplan® » Fri Nov 18, 2016 6:55 am
Really nice @sorka8888!!
Did you change to c4d?
Sroka8888
Post by Sroka8888 » Fri Nov 18, 2016 7:07 am
Yes, Cinema have the best plugin ( all things) .
Mateusz Sroka
Originalplan®
Post by Originalplan® » Sat Nov 19, 2016 2:08 am
Sroka8888 wrote:Yes, Cinema have the best plugin ( all things) .
It's true. Welcome to the C4D WorldTribe! 8)
Sroka8888
Post by Sroka8888 » Sat Nov 19, 2016 12:19 pm
GPU power
5 x GPU
780GTX - 1070GTX
Metal object (gun ACR) with maps 4K and HDR
114M samples/s
30 sec
4000x2000
1m 40sec
8000x4000
32MP
Mateusz Sroka
Post by lycium » Sat Nov 19, 2016 2:04 pm
114M samples per second, lolololol that's crazy! 8)
Post by zeitmeister » Sat Nov 19, 2016 3:00 pm
Freaky!!
Sroka8888
Post by Sroka8888 » Sun Jan 29, 2017 8:20 am
How in Indigo for Cinema apply materials with udims texture ?
I have 1001-1005 textures / and Udims UVs and this all Udims are on one object.
All body have 1001-1005 uvs.
UVs tag generator help with this ?
Mateusz Sroka
thesquirell
Post by thesquirell » Sun Jan 29, 2017 8:31 am
I don't think that's possible, atm. But, there may be a workaround. Just split your geometry based on the UDIMs, and apply the correct texture for corresponding UDIM. Kinda ruins the whole point of UDIMs, but hey, it's something. You could also try switching off the tilling option in the texture tag, and offsetting the UV to match the UDIM's space.
Sroka8888
Post by Sroka8888 » Mon Feb 13, 2017 10:45 am
||BW | WIP || SHD_TEST ||
Mateusz Sroka
Post by Oscar J » Mon Feb 13, 2017 12:13 pm
:shock: :shock: :shock: :shock: :shock:
Post by lycium » Mon Feb 13, 2017 12:39 pm
Yep, that's outrageously awesome. Well done!
