Indigo for Cinema 4D 4.0.42
Re: Indigo for Cinema 4D 4.0.42
Post by fused » Wed Aug 03, 2016 4:00 am
contegufo wrote:Cindigo 4.0.42
Can you provide a scene file?
contegufo
Post by contegufo » Wed Aug 03, 2016 7:11 am
et voilà
Sandali+bag.c4d.zip
(4.26 MiB) Downloaded 84 times
Originalplan®
Post by Originalplan® » Wed Aug 03, 2016 8:09 am
Something with the UV contegufo.....Stripes work fine. Please NOTE that is rather a tiling thing..if you click
tiling off than you can see color on the handbag.So that means Cindigo just does not handle tiling right...dunno but had this problem with the older Cindigo too.
BUT i maneged to get an error from our scene. (see image)
ALSO managed to fix it....after deleting the env material and made a new one.
Seemed like you used the older Cindigo? Anyways fixed the problem.
HATTER > refers to the name of the HDRI.
I saved it out on 32bit...after creating a new mat and adding back the HDRI seems to fixed it for good.
Originalplan®
Post by Originalplan® » Wed Aug 03, 2016 8:11 am
8) OH yeah.....did a little styling on that shoe. :APE:
Post by fused » Wed Aug 03, 2016 8:18 am
Thanks for the scene. it's a bug, I think. Will fix for next release.
contegufo
Post by contegufo » Wed Aug 03, 2016 9:40 am
Hi
Thanks for the attention. For the rest all very good, finally you can launch more istance on the Mac!.
Button "export material" not working?
arc en ciel
Post by arc en ciel » Wed Aug 03, 2016 10:01 am
the brightness value for light layers is not displayed correctly, when a value smaller than 0.001 is entered, it display 0 but the value is correct in Indigo app.
Post by fused » Wed Aug 03, 2016 10:05 am
arc en ciel wrote:the brightness value for light layers is not displayed correctly, when a value smaller than 0.001 is entered, it display 0 but the value is correct in Indigo app.
That's a general C4D issue. People have just been accepting it for decades now. Doubt it is ever going to change...
Even funnier when you consider that C4D uses double precision internally :D
arc en ciel
Post by arc en ciel » Wed Aug 03, 2016 10:27 am
ah ok sorry, I didn't know, i'm pretty new to c4d before i used electricimage and blender
contegufo
Post by contegufo » Thu Aug 04, 2016 3:20 am
ElectricImage: fast, fast, fast!!!!!
Post by zeitmeister » Thu Aug 04, 2016 6:14 am
... confirming here the "export material" issue.
Cheers, zeiti
Originalplan®
Post by Originalplan® » Fri Aug 05, 2016 12:06 am
Hello Zeit! ^^
Yep export mat does not work here too.
@contegufo good find!
Post by fused » Fri Aug 05, 2016 1:05 am
Fixed that for next release. Coming up...
Indigo for Cinema 4D 4.0.43
* Updated to indigo 4.0.43 sdk.
* Fixed material export command.
* Fixed bug where UVs would be wrong (slightly faster mesh export).
* Added global MeshCache (faster consecutive render startup times).
* Fixed a bug where instances with indigo subdiv weren't recognised as instances.
* Disabled image saving in all preview or internal render scenarios.
* Added interactive preview prototype (currently only supports updates to camera and materials, nothing that sits in the scene hierarchy).
:D
Just need to get the mac builds going...
Originalplan®
Post by Originalplan® » Fri Aug 05, 2016 1:31 am
fused wrote:Fixed that for next release. Coming up...
:D
@fused :D please do get the Mac builds going
* Disabled image saving in all preview or internal render scenarios..what does that mean? No render image into cache folder no more?
* Added interactive preview prototype = Yeeeeeeeesssssss!!!! :)
Post by zeitmeister » Fri Aug 05, 2016 8:46 am
Oh yeah!!!
Cheers, zeiti
