Old masters of Murano-Venice
Hi
Continuing in the experiments this time I engaged on the colored glasses. I used the different gradients of C4D with 4 colors for shaders.
Rendering BiDi & MLT.
- thesquirell
Re: Old masters of Murano-Venice
I'm digging that glass very much.
There is lot of dark/black aera on this picture.
In my mind this is always more bright and transparent.
This shader is a specular with a medium filtered by a bitmap?
errare humanum est
Here are the shader settings in C4D:
Ho very interesting!
Could you share the material in xml/.igm?
Because I did not know you could settle an absorption map as a shader ISL directly with C4D .
- pixie
That's a c4d gradient exported as imgJay-ko wrote:Ho very interesting!
I think that is interpreted by Indigo as a texture map.
Two other more close-up pictures. It must also say that some of the glass objects are particularly difficult as models.
Ha ok, so it is "before" the medium, at the specular definition level.
So... I think that work like a kind of vanish.
It could be awesome to have that whit a gradient of real spectrum!
errare humanum est
Here 2 images, the second one is into true specular, totally pure, and an absobtion map.
The first one is the same but with a medium with a measured green spectrum
errare humanum est
You can get a brighter image by changing the gamma = 0.5.
Latest interpretation
- pixie
I like it a lot!contegufo wrote:Latest interpretation
@pixie. Thank you!
very attractive, lacking only the DOF and sharpness of details
Users browsing this forum: Ahrefs [Bot] and 24 guests
