Hi lape,lape wrote:Component instancing does not work.
In what way does it not work?
Do you only see one component instance? Does it give an error message?
Regarding your error, looks like a blend material has an invalid child (material a or material b).lape wrote:Component instancing does not work.
I know, I should not install a beta when I have to finish a project, but now I reinstalled 3.6.28.3 and get this:
SkIndigo version: 3.6.28.3
SketchUp version: 14.1.1282
Ruby platform: i386-mingw32
Error during processing: BlendMaterialUndefined
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:8533:in `write_mat'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:8282:in `export_material'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:968:in `block in export'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:967:in `each'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:967:in `export'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:11606:in `block in <top (required)>'
-e:1:in `call'
any help?
Are you using the _dummy technique?lape wrote:I don't get an error, I only the see the component, the dummies I used for instancing just can't be seen.
Ok. The '_dummy' bit is case sensitive now, so it must be lower case. If you want to send me your scene I can try it out here.lape wrote:yes, _dummy!
Can you send me the .skp file?lape wrote:The worst thing is that i cannot get my environment map work!
Now I am back on 3.8., and this is what happens, see attached screenshots.
Can you send me the scene via dropbox pls?lape wrote:...about the instancing problem:
It only works, when the component doesn't contain other components. In my case, it is a hedge, and there are different components for leaves, branches etc. When I explode these components, and only have one major component, the dummies will work. Unfortunately this blows up my filesize....
This seems to be an issue with sun + env map with bidir enabled. Just avoid that combination for now.lape wrote:The worst thing is that i cannot get my environment map work!
No, it also doesn't work using path tracing, can't get the sun layer working while environment map is in use! And if you use camera instead of reinhard, everything turns black...OnoSendai wrote:This seems to be an issue with sun + env map with bidir enabled. Just avoid that combination for now.lape wrote:The worst thing is that i cannot get my environment map work!
