SkIndigo 3.8.6.1
Re: SkIndigo 3.6.8.1
That's it now. Cheers!
Super fast export from 2nd time on! Great!
I've tried without problems (SU2014).OnoSendai wrote:So... anyone tried it?
Greatbubs wrote:That's it now. Cheers!
Takes a little while to debug these dynamically-typed language programs
I'll take your word for it...
I'm getting this error when I try a clay render;
Scene parsing error: While processing node 'Group#6', UID 208: Failed to find material for UID 109
I've tried it on several different scenes but the message is always the same.
ok, will fix clay render.
Just found a way to make the subsequent exports maybe 2x faster
Fantastic!OnoSendai wrote:Just found a way to make the subsequent exports maybe 2x faster
Here's another one for your list...
Scene parsing error: While processing node 'Group#11', UID 812: Referenced node (UID 481) did not have type SceneNodeMaterial
Can you send me that .skp file?bubs wrote: A problem occurred with the scene:
Seems ok for me so far. Old scenes open up and render correctly.
Subsequent export time on my test scene is down from 20s in old SkInidigo, to 1s now. 20x speedup!
Sent you a link. It's a scene I just recently finished which exported and rendered perfectly with 3.6.28.3 (and still does, I just re-installed to check)OnoSendai wrote:Can you send me that .skp file?bubs wrote: A problem occurred with the scene:
Thanks, will check out.
Have uploaded a new version that should work.
Still having issues with that scene I sent you. But other scenes seem to be working OK and Clay seems to be working.
Scene parsing error: While processing node 'Group#11', UID 925: Referenced node (UID 481) did not have type SceneNodeMaterial
Subsequent scene export time down to 0.7 s now (from the 20 s original time)
