IndigoMax - Error
IndigoMax - Error
I have a problem....
I can't install IndigoMax higher than 0.3.6 because is a error:
Error opening file for writing:
\plugins\IndigoMax.dlr
My max version:
3ds Max Design 2014
Any ideas how to fix this ?
I test old IndigoMax version, and i want test new Changes
My max version:
3ds Max Design 2014
Mateusz Sroka
Platige Image - Lighting / Shading / Look Development Artist, Environment Artist
Re: IndigoMax - Error
Was max root path specified correctly?
Seems like it was left blank. If that's the case please try to set it manually. Will check if auto-detection works for Design.
Hope it helps,
Hope it helps,
Indeed, there was a problem with path auto-detection for Design versions. It was fixed already, so please re-download installer for testing.
Thanks for info.
Thanks for info.
Auto-detection for Design versions Works
But Error is still
When i click ignore, next file have Error and next, next ...
It looks like the files are protected
I check file ,and are not set only to read hmm...
Its strange the version 0.3.6 works, but higher don't...
hmm version 0.3.6 have different installer than 0.3.9 ?
But Error is still
Mateusz Sroka
Not really, you might see on your screenshots it's copying files to empty path. Which is a bug. Will look into it.Sroka8888 wrote:It looks like the files are protected
Yes, it was changed in 0.3.7Sroka8888 wrote:hmm version 0.3.6 have different installer than 0.3.9 ?
Thanks for info.
I have fixed some issues with installer script in new release. Hopefully they should solve your installation problems.
Please let me know if it's working for you.
Works Thank you very much
Mateusz Sroka
I'm glad it's working for you
I need your help.
- How in 3ds Max (IndigoMax) create proxy, something like VrayProxy?
(I want have one "base" Model and others instance - box)
- Where is Mesh Subdivision?
- Where i can find Maxigo Scatter?
- Why when i set Interactive mode render works ,but i have a lot of message --Unknow property: "value" in dotNetControl:render_progress:(null) ?
- I want start render but i have message Error Creating File Output
I need your help.
Mateusz Sroka
That's something I'm currently working on, should be in next release.Sroka8888 wrote:How in 3ds Max (IndigoMax) create proxy, something like VrayProxy?
I don't know, possibly in Maxigo.Sroka8888 wrote:Where i can find Maxigo Scatter?
This is addressed in next 0.4 seriesSroka8888 wrote:Why when i set Interactive mode render works ,but i have a lot of message --Unknow property: "value" in dotNetControl:render_progress:(null) ?
Could you elaborate a bit? Screenshot, replication steps?Sroka8888 wrote:I want start render but i have message Error Creating File Output
Thanks,
