Great rig you have by there Voytech, impressive.SCHMUMS wrote:Thank you so much!
should go for today you already much!!!
community need for renderings
Re: community need for renderings
It does well in bidir. Late 2008 Mac Pro dual xenon 3.2Ghz (16GB Ram) and SSD. Sadly, with Open CL on, the 2012 Ivy Bridge i7 iMacs are faster by about 5%.CTZn wrote:Great rig you have by there Voytech, impressive.SCHMUMS wrote:Thank you so much!
- Polinalkrimizei
ok going for 259_2 right now... the 251_2 is rendered already.
Is that ok?
Is that ok?
wait wait i calculing a 259
can you calculate the rouleau_feuilles_hd??
and check that the bump is double sided 0.0001
C4DR11.5-R12 user-Quad core Intel Xenon 2X2,26 GHZ
Zbrush 4
Zbrush 4
- Polinalkrimizei
Check! Bump setting was ok!
great!!
Can you calculate it?
Zbrush 4
Zbrush 4
I opened rouleau_feuilles_hd.pigs just to see what it was and I'm really awestruck. Beautiful geometry and light. So if you don't mind, I'll let it cook (render) fully. It was warning me about IES lights again but it looks ok. Looks like I'm hovering around 2ssp per minute (bidir) so it should be quite good by the end of day.SCHMUMS wrote:great!!
let's go!!
Zbrush 4
Zbrush 4
Voytrech,
can you send me a screeshot of rendering being calculated?
thank
Olivier
thank
Olivier
Zbrush 4
Zbrush 4
Here you go.SCHMUMS wrote:Voytech,
thank
Olivier
Very great
you can continu
you can continu
Zbrush 4
Zbrush 4
Not sure when you need the render by, so here's a current render: https://app.box.com/s/d3t3ft9qn6y6ml37j3cw (only about 400ssp). I'll let it run and post the result at 8am EST tomorrow.
it is already very good. I expect tomorrow. thousand thank you tomorrow morning
Zbrush 4
Zbrush 4
I agree with Voytech. Beautifully abstract art. It would be very interesting to know what it's used for!
Ok. Here's the final render https://app.box.com/s/d3t3ft9qn6y6ml37j3cw
Went up to 1800ssp or so. Forgot to look.
