In the scene pick the desired object, set to invisible, save the scene and presto! ;)delle wrote:Could you please suggest the igs-code to enable this option?Added invisible to camera option to models.
Thank you very much.
A.Delle
Indigo Renderer 3.6.9 Beta Release
- pixie
Re: Indigo Renderer 3.6.9 Beta Release
THX .. very nice
This is awesome!
One thing: when using Edit > Copy Image and pasting into Photoshop, the alpha transparency is not preserved (noisy black and white background where it should be transparent). Saving to a PNG works fine.
- Antonis777
Some problems in the new release. Image takes far too long time to update if I tweak with light layers or material settings or anything else. Sometimes it crashes. No specific problems with previous releases.Also I downloaded CTZn's material http://www.indigorenderer.com/materials/materials/961 and got this result (don't know for sure though if it's abug of the new release).
The tag is not written by Indigo yet, it can not be implemented without a fix or more intel.pixie wrote:In the scene pick the desired object, set to invisible, save the scene and presto! ;)delle wrote:Could you please suggest the igs-code to enable this option?Added invisible to camera option to models.
A.Delle
@Antonis: I don't think that the shader should break the mesh like this. Perhaps it's my code clamping the coordinates but I found similar shading limitations in different circumstances.
- pixie
OMG sloppy programming, it can't be! xDCTZn wrote:The tag is not written by Indigo yet, it can not be implemented without a fix or more intel.
From me it's iterative empirism, from Glare it's a beta feature :)pixie wrote:OMG sloppy programming, it can't be! xDCTZn wrote:The tag is not written by Indigo yet, it can not be implemented without a fix or more intel.
SPOILER:
and here's the kitty:
on the model
<invisible_to_camera>true</invisible_to_camera>
CTZn wrote:SPOILER:
and here's the kitty:on the modelCode: Select all
Scene parsing error: Found unexpected element 'invisible_to_camera'. (In element 'model', around line 103, column 1)
I think you will have to use the <model2> tag.CTZn wrote: As it seems there is no XML support (at all ?) at this point.
ouch that's heavy stuff. I think someone was writing a doc on this guy ?
Amazing new features otherwise.
Hi! in this release not working "assign materials". Not so good)
Cool release! Just tested the DOF pass and it works great! Here's an idea: when enabling the "depth pass" rendermode would it be possible to "hide" all existing light layers and to rename (or substitute) the first one with the name of "depth pass" or something similar (being this operation reversible when one goes back to a traditional render mode)? at the moment all layers are kept and it's not immediate to understand that the render pass is only in the first one, maybe called in some other way ("sun" in my case :) ).
Tested the "invisible to camera" too: cool and handy. Is there a way I can hide lights from reflections too? :D
Er... DOF and Z-depth are two completely different things. Just to be clear, I'm assuming you mean the Z-depth pass?Pibuz wrote:Cool release! Just tested the DOF pass and it works great!
ER ops: yes I meant that :D
I made a mess since I use that in photoshop to change the dof focus :D
Users browsing this forum: Ahrefs [Bot] and 49 guests
