[REQ] Shadow Catcher material...
- zeitmeister
Hey Ono,
just coming up again with an old request...
Re: [REQ] Shadow Catcher material...
Now maybe even easier to realize since we have some proper alpha rendering mode?!
How is this shadow catcher hack supposed to work again?
+1
Best for photo montage renderings.
It should be a tag or material for a (free to define) ground mesh that only gets "colored" by shadow rays.
Actually its the renderpass "shadows" for that object only or so...
- zeitmeister
Yip.
This would be a full shadow pass mode associated with a shadow material.OnoSendai wrote:How is this shadow catcher hack supposed to work again?
If the second eye vertex (first being camera) is not hitting a shadow material -> render white
If this is a shadow material -> render the resulting radiance divided by shadow material albedo.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
That could work somewhat. Would only really make sense for Lambertian shadow material.galinette wrote:This would be a full shadow pass mode associated with a shadow material.OnoSendai wrote:How is this shadow catcher hack supposed to work again?
Etienne
Also I don't know if the workflow is good as you would have to render out a separate shadow pass and composite together.
Yup, forgot to tell thatOnoSendai wrote:That could work somewhat. Would only really make sense for Lambertian shadow material.
I thought this was the request. There are other 1-pass solutions with envmaps, but it's very impratical for unbiased renderers.OnoSendai wrote:Also I don't know if the workflow is good as you would have to render out a separate shadow pass and composite together.
I will try an approach something like this. Basically I will define the 'unshadow fraction' to be something like reflected occluded luminance divided by reflected unoccluded luminance.galinette wrote:Yup, forgot to tell thatOnoSendai wrote:That could work somewhat. Would only really make sense for Lambertian shadow material.I thought this was the request. There are other 1-pass solutions with envmaps, but it's very impratical for unbiased renderers.OnoSendai wrote:Also I don't know if the workflow is good as you would have to render out a separate shadow pass and composite together.
- zeitmeister
It would be great as a pass, for sure.
But it would also help a lot as a shader!
Imagine just placing your model in front of a backplate and assign that shadow material to a floor... ready.
I really would appreciate that option!
Why did you have to wait until I implement it the other way before you say how you want it? sigh.zeitmeister wrote:It would be great as a pass, for sure.
Just because you are so fast and nobody expected to see some results within days ^^OnoSendai wrote:Why did you have to wait until I implement it the other way before you say how you want it? sigh.
Another big benefit would be Background replacement via a HiRez image to be done directly in Indigo for fast composition, without doing 1001 renderings in Indigo and putting stuff together in PS...
This can be done with a background plate in the scene directly right?Zom-B wrote:OnoSendai wrote: Another big benefit would be Background replacement via a HiRez image to be done directly in Indigo for fast composition, without doing 1001 renderings in Indigo and putting stuff together in PS...
Users browsing this forum: No registered users and 90 guests
