Indigo Renderer 3.6.6 Beta Release
Re: Indigo Renderer 3.6.6 Beta Release
A good third of my posts is due to an absence of FAQ.
+ 2k+ for a FAQ, I'll be sure to contribute here and there.
wonderfull!!!!!and very fast!
radiosity
radiosity
There already is a FAQ online at Support > FAQ ;)CTZn wrote:A good third of my posts is due to an absence of FAQ.
I can't edit it, no wonder that I came to forget about it. I can still submit entries internally.Zom-B wrote:There already is a FAQ online at Support > FAQ ;)CTZn wrote:A good third of my posts is due to an absence of FAQ.
...I don't know if I'm using it correctly but when I try to add a normal map the materials turns out all black
Normal maps work fine here.Pibuz wrote:...I don't know if I'm using it correctly but when I try to add a normal map the materials turns out all black
..well ok: is there anything I should know before using normal maps? some particular range values, or something like that? I tried with values which worked with the bump map (0.001m) but that didn't work..
I'll post my test in some minutes..
All values should be default. scale (b) should be 1.Pibuz wrote:..well ok: is there anything I should know before using normal maps? some particular range values, or something like that? I tried with values which worked with the bump map (0.001m) but that didn't work..
..indeed!
With the B value of 1 it works!! Now, testing with different values!
EDIT: values smaller than 1 make the material render black
Hi, I set the render resolution to 4000x3000pxl, in 3dmax, but when start the indigorenderer interface, the resolution in 1000x700 as a free version...can you help me?sorry for my poor language
Is you want to render in higher resolution you need to BUY Indigo first ;)radiosity wrote:the resolution in 1000x700 as a free version...can you help me?
I BUY ITZom-B wrote:Is you want to render in higher resolution you need to BUY Indigo first ;)radiosity wrote:the resolution in 1000x700 as a free version...can you help me?
I DO NOT SEEM RUDE I WANTED TO ASK YOU SORRY!!!!! BLAME IT is THE MY BAD ENGLISH !!!SORRY, AND THANKS FOR THE ANSWER!!
SORRY FOR MY POOR LANGUAGE!!
RADIOSITY
whenever I run into problems like that, I always try to reinstall first to see if the problem resolves itself
also make sure you don't have any non-standard characters in the file names, this seems to be a problem from time to time
Hey, take it easy mate :) I'm pretty sure Zom-B didn't want to insult you in any way. The thing is that 1000x700 is the limitation of demo mode of Indigo. So, in case you've received a license key for you hardware, you have to enter this number to Indigo. Start Indigo > "Help" > "Licensing" > "License keys" tab > enter a proper key for you hardware > OK = Done. These steps unlock the demo mode and no limitations are goind to stand on your way to uberphotorealistic images :)radiosity wrote: I BUY IT
RADIOSITY
P.S. There are forums for different languages, check'em out in case you feel expressing yourself better in your mother language.
You can also post your general questions here, in italian: I'll translate them. I'm sure it's ok, since this forum is more visible and so all the skilled users will see and help..
Puoi anche postare le tue domande generali qui, in italiano: te le traduco io. Sicuramente va bene, dato che questo forum è piu visibile e tutti gli utenti piu esperti vedranno e ti potranno aiutare..
Users browsing this forum: No registered users and 129 guests
