indeed, it was the default cindigo setup, once I took off the env light all things behaved as they should :)Zom-B wrote:The reason for this seems to be Indigos auto importance weighting for lights. Your scene has 2 light sources, a mesh light and the envSphereGeometry. The scene with emission not set get calculated flux value automatically and end sup with 1000 times stronger difference between the both light sources. Now the stronger Light also get 1000 times more computation time, and the weaker light stays noisy for ages still contributing to the whole image with the massive amount of noise...pixie wrote:Some groovy stuff. Same scene rendered for 1 minute, one has emission scale set and another doesn't.
This example shows how important a good balance between light sources is, and maybe also that Glare should allow to tweak the importance directly in the future (even on the fly, in the LightLayer tab...)
Indigo Renderer and Indigo RT 3.0.12
- pixie
Re: Indigo Renderer and Indigo RT 3.0.12
Sorry if this question was already asked, but has anyone tried to use GPU accelation with a HD 5850? The only thing that happens for me is that... 0ks/s and updating image. Is it possible to fix this bug? (I`m using Catalyst 11.6)
Yep. Updating image forever and then some...
The one time I tried GPU accel my pc froze with a 5770.
Hi Vasco,vasco wrote:Sorry if this question was already asked, but has anyone tried to use GPU accelation with a HD 5850? The only thing that happens for me is that... 0ks/s and updating image. Is it possible to fix this bug? (I`m using Catalyst 11.6)
This should hopefully be fixed in 3.0.13, which we will release on Monday.
J'ai voulu passer à Windows 7 en 64 bits afin de procéder à différents tests. J'ai installé Indigo est Skindigo comme d'habitude et un message d'erreur s'affiche lors du lancement d'un rendu dans Sketchup :
Indigo est installé dans mon disque dur D: (D:\Applications\Indigo Renderer\indigo.exe
Si je supprime et réinstalle Indigo dans le répertoire par défaut (C:\Program Files...), il ne se passe rien lorsque je clique pour lancer un rendu. J'ai essayé avec la version 32 bits, idem.
Je comprends pas là ?
(Indigo se lance correctement si j’exécute directement "indigo.exe").
Hey OnoSendai,OnoSendai wrote: Hi Vasco,
Monday when?
Hi Vasco,
Sorry about that, it took a bit longer to get the release ready than I thought.
We should be releasing today or tomorrow.
hey Ono!OnoSendai wrote:Hi Vasco,
this link works:
maybe bad buid?
Hi snorky,snorky wrote:hey Ono!OnoSendai wrote:Hi Vasco,
this link works:
maybe bad buid?
could you maybe not post these links to unreleased builds anymore? (otherwise we have to stop putting them on the website )
sorry :(fused wrote: Hi snorky,
could you maybe not post these links to unreleased builds anymore? :) (otherwise we have to stop putting them on the website ;) )
Glass acceleration doesn't seem to help water stuff. Maybe because it's a volume?
Glass has a volume too. I'd assume that it has more to do with the fact that the volume is enclosed by coplanar faces.
Ono please add external material support and linux build, would be really appreciate
thx
thx
That's why we didn't call it water accelerationCoolColJ wrote:Glass acceleration doesn't seem to help water stuff.
In all seriousness, the GA is intended to be used for thin sheets (not single interfaces) with low curvature.
Is it possible to change the exponent for phong materials from the UI? I can only see IOR.
