Render Speed comparison (I7 2600K)
Re: Render Speed comparison (I7 2600K)
Erotica, not catterpillar - sry ma bad
dcm wrote:Cool....i OCed 2600k to 4,0GHZ Stable with 1.18V for core !!!! As cooler i have Scythe Mine 2 on ultra low fan speed. With Corsair PSU is total silent pc during long renderings
Erotica 1400spp, cpu have 68 celsia after 1 hour of rendering! Thats awesome. I have still some space to push it up (probably 4,6ghz with 1.25vcore but temps will be higher).
Damn, I might just have to buy one, I feel really inefficient pumping out tons of heat with these old overclocked things. 68C is getting a bit hot, you migth want to turn your fan up a bit ;p What's the ambient room temp when you recorded 68C?
about 22C. On stock clock i have 30C in idle / 55C burn
Just as info, you can push the 2600k to the 4.5Ghz without problems for 24/7 or even to 5ghz if you have a good batch.
I fixed my Setting to 4.4Ghz, to have adorable temps.
results after 30min:
Caterpillar 520k/sec
Erotica 1490k/sec
Pintest 1050k/sec
62°C Load
32°C Idle @20°C roomtemp
regards
Erotica 1490k/sec
Pintest 1050k/sec
62°C Load
regards
C4D R20 Studio
mad-imagery.com
mad-imagery.com
Looks like I may have to upgrade when the next chip after this lot comes out, hopefully with 8 cores
Seems like they run much cooler so, 8 cores in a single chip should be fine.
No point in upgrading if I don't get more cores. And Intel finally puts in native USB3 support
Next gen Intel chip should be 50% faster than an I7 930, plus add 4 more cores and that's nice
With GPU acceleration, a complex render should be done in 2-3 hours tops, off course water renders are a different thing altogether
- pixie
I just loooove when women talk dirty! xDCoolColJ wrote:Damn that's about double my CPU - WTF!
ROFL!pixie wrote:I just loooove when women talk dirty! xD
I don't think that you become a female just by having a avatar that may point in that direction
Here my test to whom it is interesting.
XEON 5506 2.13Ghz, without HT
Caterpillar 480.64
Erotica 1348
Pintest 1357
Caterpillar 480.64
Erotica 1348
Pintest 1357
Users browsing this forum: No registered users and 52 guests
