Hello guys, i have win 7 and su 8, when i click on "render scene" Indigo don't start, if i click on "Set Indigo Path" appear thi error:
"If Skindigo cannot find Indigo in your default applications folder, it will use the patch to Indigo as specified."
Thanks.
SkIndigo path problem
Re: Skindigo Problem
Hello Nick,
I am not sure but there should be a way in SkIndio to tell it where Indigo was installed. You probably specified a custom install path for Indigo and that may be why SkIndigo can not find it ?
Please give a more specific title to topics when applicable, like "SkIndigo path problem".
Thank you.
Thank you.
Re: SkIndigo path problem
Title changed.
I have installed Indigo in the root directory. C/programs/Indigo Renderer
Thanks.
Thanks.
Hi Nick,
please specify what do You mean when saying "indigo don't start" - does export process starts? Or nothing happpends at all?
If export works, try to save exported scene, open indigo from desktop and try to renderer.
If export process doesn't start, then there's problem with exporter (skindigo) and not indigo's path.
Make sure that You use both indigo's and skindigo's latest versions
cheers
wojtek
cheers
wojtek
Hi wojtek-w!
When i click "Render Scene" nothing happens.
EDIT: I solved the problem by reinstalling SU 7.1
