by suvakas » Sun Oct 14, 2007 12:24 am
I think i fixed the bug.
Scene scale for first image is mm and for second image it's cm.
- 833-cm.jpg (111.65 KiB) Viewed 3217 times
- 833-mm.jpg (72.25 KiB) Viewed 3217 times
Xman
by Xman » Sun Oct 14, 2007 1:31 am
Thank suvakas, and I'm sorry forget amend 3dsmax of units.
update waiting for you are Maxigo
Xman
by Xman » Sun Oct 14, 2007 1:41 am
I met a new problem today.
At some scene, Indigo working 10 or 20 minutes hereafter, Indigo auto stop.
Who have similar problem?
by suvakas » Sun Oct 14, 2007 2:50 am
Make sure you don't have any specific time amount or NumberOfSamples entered into Maxigo
Check the log file after the rendering stops.
Xman
by Xman » Sun Oct 14, 2007 3:08 am
suvakas,
maybe you test the scene.You can know more clear.
From my test,The problem at 7 ~ 12 minutes. AMD3800+X2 2G RMB
From my friend,The problem at 10 ~ 14 minutes. E6300 2G RMB
- TEST.png (705.58 KiB) Viewed 3204 times
Xman
by Xman » Sun Oct 14, 2007 3:10 am
scene
- TES.rar
- (2.32 MiB) Downloaded 261 times
by suvakas » Sun Oct 14, 2007 7:11 am
Xman wrote:suvakas,
Cool scene Xman. I like it!
On my quad core it finishes after 5 minutes
This is not a bug. It is a feature. Check out the screenshot. Indigo automatically finishes rendering after it reaches the amount of samples that is entered into that field. In your case it is 100. This feature is very useful for animations for example. If you want Indigo to keep rendering forever, then leave that field to zero.
- number_of_samples.jpg (42.46 KiB) Viewed 3190 times
Xman
by Xman » Sun Oct 14, 2007 6:09 pm
Thanks suvakas,I get it Now
Xman
by Xman » Fri Nov 02, 2007 7:41 am
suvakas,it is a new problem.
Looks if use Milllimeter, it can't work accuracy.
3ds Max9.0,indigo v1.0.1,Maxigo0.9.4a
- Milllimeter and Ctest copy.jpg (329.66 KiB) Viewed 3064 times
Xman on Fri Nov 02, 2007 7:44 am, edited 1 time in total.
Xman
by Xman » Fri Nov 02, 2007 7:44 am
scene
- max for scene.rar
- (821.35 KiB) Downloaded 239 times
by Kram1032 » Fri Nov 02, 2007 9:42 am
millimetres means, your scene is 10x as big as before...
SO, you need to increase your ray nudge distance by ten times
by suvakas » Sat Nov 03, 2007 1:26 am
Xman wrote:suvakas,it is a new problem.
"Display units" can be whatever you want to see writen behind your units on Max interface (it could as well be your granny's name
). The real units Max uses for the scene are under "System Units Setup". In your case it's inches. So when you use millimeters your model gets very small and that's why there are artifacts. You should use inches for this model or you can scale your scene to use millimeters. To do that change your System Units to millimeters and reopen your scene. From the dialog that pops up pick "Rescale the file to the system unit Scale".
Ps. Maybe i should add a check box to Maxigo that auto-picks the units from Max System Units panel.
Users browsing this forum: No registered users and 76 guests
