It's bug?(Update 02.11,2007)
Xman
Post by Xman » Sun Jul 22, 2007 7:03 am
Hello suvakas,
from Maxigo-7 to Maxigo-9,have same mistake, is this a bug? :(
thank.......
_Xman_
Xman
Post by Xman » Sun Jul 22, 2007 7:04 am
The result of mistake.
Kosmokrator
Post by Kosmokrator » Sun Jul 22, 2007 7:04 am
what mistake xman?
aahh....r u use fix mesh errors mode 1 or 2?
Xman
Post by Xman » Sun Jul 22, 2007 7:05 am
Max7.0 scene
chair.rar
(46.63 KiB) Downloaded 139 times
Xman
Post by Xman » Sun Jul 22, 2007 7:08 am
Sorry Kosmokrator,I have no meaning that comprehends you :?
Kosmokrator
Post by Kosmokrator » Sun Jul 22, 2007 7:09 am
for me work perfect Xman.....just enable the fix mesh error button!!!
Xman
Post by Xman » Sun Jul 22, 2007 7:18 am
Kosmokrator wrote:just enable the fix mesh error button!!!
Arrive where amend?
thank you, :)
_Xman_
Kosmokrator
Post by Kosmokrator » Sun Jul 22, 2007 7:25 am
use this plz..
Xman
Post by Xman » Sun Jul 22, 2007 7:47 am
Thank you very much,Kosmokrator.
Thus fine provide instruction for me. :D
Kosmokrator
Post by Kosmokrator » Sun Jul 22, 2007 7:50 am
no prob.... :wink:
Xman
Post by Xman » Fri Oct 12, 2007 9:45 pm
Hi everyone,
The same problem come again,Who can tell me how to do?
(Because Maxigo0.94 no Fixmesh error now)
Thanks all
___Xman___
indigo_v09t8 and Maxigo0.9.4.jpg (256.72 KiB) Viewed 3226 times
Post by suvakas » Fri Oct 12, 2007 10:49 pm
Hi Xman,
Can you upload the max scene file so i could take a look at this?
[edit]
Why did you model those pieces as a separate objects? One lathe should be enough for those.
Xman
Post by Xman » Sat Oct 13, 2007 12:47 am
Hi suvakas
I can,But need to be tomorrow can upload the scene.
thanks :D
Xman
Post by Xman » Sat Oct 13, 2007 2:17 pm
suvakas,
This's Scene :)
833.zip
(2.25 MiB) Downloaded 135 times
Post by suvakas » Sat Oct 13, 2007 8:07 pm
I checked you scene.
It seems to be a scale related issue. For some reason Maxigo doesn't scale your scene correctly to millimeters.
Your system units in Max are set to inches and you are using centimeters as your display units and millimeters in Maxigo. In what units did you actually model the scene? Try to use Centimeters or Inches in Maxigo and see what happens.
In theory Maxigo should scale the units correctly though. That means there might be a bug somewhere. So thanks for the scene. I'll try to find the bug if i get some more time.
Here's an image rendered using centimeters for the Scene scale in Maxigo.
Users browsing this forum: Majestic-12 [Bot] and 1 guest
